Question about Panasonic Home Theater System System
Cd stuck in player. Won't eject.Read-out says "chgr error"
  • Anonymous Dec 25, 2008
    The
  • 4 Answers
The cd changer unit get struck so you have to reassemble the unit by a technician
Posted on Dec 25, 2008
Show a diagram on how to get cd stuck in 2006 f150 out. Cd stuck and tried but it won' come out
Look to see if there is a tiny hole on the front of CD player just under the tray.that is the access point for a paper clip.if there isn't one...try turning ignition off then whilst holding the eject button turn on the ignition and do not release eject button.
you may need to try this several times.what you are trying to do is beat the cd from trying to read the cd as this seems to over ride any eject commands on some machines.if all of the above fail you may need to remove entire unit from dash to gain access .
Feb 12, 2015 | Ford F-150 F150 Extended Cab
Cd gets stuck in recorder makes clicking sound..
I would just guess that the belt that is in the eject mechanism is now stretched- That is if there is a belt. That is very common in all CD player units.
Feb 12, 2015 | Tascam Dp-02cf Digital 8-track Recorder
Bose 3 cd playerdisc error will not eject
Try to use an old CD...and insert it under the stuck CD...push in slightly while using the eject button...on may models this will release the stuck CD...Hope this helps.
Nov 25, 2011 | Audio Players & Recorders
CD will not eject in my multi CD player. Get CD error
I decided to buy a better radio/cd player and have it installed.
Jan 05, 2010 | 2004 Ford Thunderbird
2005 s40 cd(holds 6) player stuck - reads deck error?
that is one of worse nightmare when you have a magazine loader in the systems when the cd get stuck. its common to all cd player some has better luck than others, Only thing I recommend is to take it to your local stereo shop or do it your self taking the unit apart and remove the cd. Keep in mind, when having magazine loader, some of the older unit will not read the new format or burn disk and it will read no disk or error and the cd will get lock. if the unit cant read the cd, majority of the time its does recognize there is a cd in unit. try tuning on and off couple of time and keep pressing eject button. you may have to do it 8-10 times to see if that will release the stuck cd.
Aug 27, 2009 | Car Audio & Video
CD stuck in my car CD player and cant eject it when i hit the ej
it may be you have a paper label on the cd most car cd player won,t handel paper lables not enuf room as for getting it out try this get a light and see if you can see the cd if so take a pop sickle stick with a small amount of super glue on tip and be vary careful put the pss in to opening to the edge of cd let set for a few seconds then try pulling it out when pushing eject donot use but vary little super glue i have done this on some cd player
Mar 26, 2009 | Car Audio & Video
2004 Jetta CD Player Won't Read CD's
I had the same problem when I first got it.  I realized that the problem was the CD I was putting in.  The CD player will NOT read burned RW CDs.  I hope that helps!  But it will read burned R CDs and ones from the store.
Dec 21, 2008 | 2004 Volkswagen Jetta
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Panasonic Home Theater System System Logo
394 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
