Computers & Internet Logo
A
Anonymous Posted on Sep 03, 2012
I have a Compaq CQ61-319WM & when I turn it on the screen is black, the caps & the # locks key blinks...what could be the problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 04, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
207
Points
0
Whoever wrote the answer to this is awesome. I have the same type of computer and it would not turn on even though the charging light was on. So I took out the battery and unplugged it. Then repeatedly pushed the power button. After that I put the battery back in and pushed the power button and it worked! Thank you sooo much!!
1 Related Answer
adracamas
Bryan Daugherty
  • 344 Answers
  • Posted on Mar 24, 2011
SOURCE: HP G61 NOTEBOOK PC BIOS
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
Caps locks blinks for compaq
Press the Caps Lock key once to stop it blinking. If the key is stuck down slide a butter knife or thin screwdriver down one side of the key and lever it upwards just enough to free it.
Hp g56-125n notebook caps lock blinks continuously blinks and black screen
When caps lock blinks it means the computer is either having a problem or DESPERATELY needs to tell you something (like when you run diagnostics and encounter a error). Hope this helps!
Turn on power.caps lock blinking light,f10 button is amber,screen is black,help
first remove ram and clean gold track with pencile rubber then try to boot
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Compaq memory
Remove one at a time, and try to reboot, alternate one for the other. Remove the battery, leave battery out, and unplug each time during process. The Cap Lock? Does the HDD led blink? Do you get anything on the screen?
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
4helpful
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
23helpful
4answers
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
30helpful
2answers
My laptop presario cq40's monitor is not displaying anything. but caps lock key and scroll lock is blinking automatically
my laptop presario cq40's monitor is not displaying anything. but caps lock key and scroll lock is blinking automatically
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
Grand Canyon Tech
Grand Canyon Tech
