By LiZzIe - usenet poster
My TV turns off by itself. How do I correct this?
30 Other Users Have The Same Problem
Comment by Guest, posted on Oct 13, 2008
My four year old RCA just turned on all by itself and began changing channels and increasing in volume. It says it is searching, but is is hooked up to cable. I left it unplugged for some hours, now it just turns on and off every half-second. Any idea what the problem may be?
Comment by Guest, posted on Sep 23, 2008
We have a 27 inch Norcent TV that was turning off by itself about every hour or so and more recently it turned off every minute. Now the TV has absolutely no power to it at all. It just died. The TV is only 4 years old. Has anyone been experiencing this problem?
Comment by marsha_subad, posted on Sep 19, 2008
i have a toshiba 32 inch television and after 3weeks it started powering off on its own after half and hour. what can i do to solve this
Comment by ntur, posted on Aug 26, 2008
my TV did the same thing and also would have Hiccups, tv would blank for a 1/2 second but resume. Finally it would not come back on. I figured it died. Then I hooked up another TV. It Hiccupped. Could it be the cable box? The box was pretty warm. I have now hooked up another box. If it happens again I will check my electrical plug which I have been using for 20 years..If it is the cable box then it ruined my big TV
Comment by arelliczar, posted on Jul 27, 2008
my jvc 32'' tv turns on and off by its self and changes the channels and volume its crazy i unplugged it for like 3mo last summer and when i tried it again nothing seemed to be wrong with it now it is doing the same thing again how do i fix it.
Best Solution
posted on Mar 31, 2008
Rank:
Apprentice
Rating: 94%, 20 votes
I have 56" DLP Rear Projection TV, it turns off by itself at random times. Can you please advise.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 23, 2006
Rank:
Wiz
Rating: 79%, 450 votes
Check for cold solders points, many times is the problem, recheck every poor solders.. nice? ok
Solution #3
posted on Feb 26, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
the cold solder points do not explain why the tv comes back on after it goes off.
Solution #4
posted on Aug 08, 2005
Powe33 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. If this does not correct the problem, you may need to have your TV serviced.
Solution #5
posted on Jul 16, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
My TV does that and i have to keep turning it on then after about 5 minutes of frustration it somehow warms up and i can watch tv so if you can just keep pushing the power button on the tv and wait about 5 sec for sound and then it turns off then after thaat about 10 times wait a minute and keep doing the 5 sec thing until it turns on
hope it helps
Solution #6
posted on Jun 07, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
Sometimes when the tv is old welds stop conducing... so you hit the tv and it works... you should check for some bad (usually white) weldings and solder again.
Solution #7
posted on Oct 28, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
check if the auto timer on/off has been turned on. this can be accessed from the menu
Solution #8
posted on Oct 23, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
My TV keep't turning off on its own, very frustrating so I had it checked out and it turned out to be broken joints in the soldering that lead to the power supply.
Hope this helps.
Big E
Solution #9
posted on Sep 22, 2007
Rank:
Apprentice
Rating: 75%, 4 votes
Check to see if the Sleep Timer is on.
Solution #10
Rank:
Apprentice
My GE manual suggests you check to see if your sleep timer is on when this happens.
Solution #11
posted on Aug 17, 2007
Rank:
Wiz
Rating: 78%, 135 votes
welll sometimes if you have your tv on sleep mode this might also turn it offf
Solution #12
posted on Apr 25, 2007
Rank:
Apprentice
Rating: 70%, 2 votes
when its pluged on the fuse will cut of
Comment by BADMAS, posted on Apr 25, 2007
WHEN ITS POWER ON POWERSUPPLY FUSE DAMAGED CUT OFF
Solution #13
posted on Mar 16, 2007
Rank:
Guide
Rating: 81%, 7 votes
checked the big low voltage power supply capacitor if it is not dried up
Solution #14
posted on Apr 16, 2006
Rank:
Apprentice
Rating: 80%, 3 votes
I have the same problem that TV turns off automatically after 3 minutes 2 minutes or something like that.
I do not have any power outage. Shall I just Connect it to the Direct wall socket
Comment by bokya, posted on Apr 16, 2006
Please let me know ASAP
Solution #15
Rank:
Apprentice
Rating: 81%, 15 votes
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
The flashing then pauses for approximately 1/2 second.
The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Good luck! ...Lates...
30 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 19, 2008
keeps clicking on off
Comment by Guest, posted on Jul 12, 2008
SAmsung has a manufacturer's defect with their tv's that are shutting off by themselves - samsung will not admitt this to the public but rest-assurred I have access to inside information. The TV's need to be taken in for service with a good quality tech.
Comment by zoey6106, posted on Jun 14, 2008
My tv keeps turning off after 30 seconds and sometimes after an hour. I have tried other outlets and it still continues to turn off- What causes this to happen and should I just dump it and buy another tv?
Comment by Guest, posted on May 28, 2008
My Samsung TXN3245 same problem but the only difference is when you unplug the Tv an wait for several hrs. and turn it on but will turn off after about 10-15 minutes.
Thanks for any advise
Comment by czebotarj212, posted on May 12, 2008
I have a Magnavox Model # MS3252S431, the picture and color seem fine as well as the audio. However, when I turn it on- usually 2-3 min later it wll either A) Picture goes out, clicks back on, then couple seconds later pic goes out, clicks back on, and usually by the 3 time it clicks off it stays off but my tv power light is still on. or B) It shuts off and stays off- w/ the power light still on. It seems once i turn it off and back on it's fine again though I may have to do this every 20 min or so, then afer a good warm up it doesn't seem to happen?- Or not that I'm aware of? Please help-any recommendations would be helpful.
Comment by Guest, posted on May 10, 2008
tv turn,s off itself you sometimes have too bang on top of the tv
toshiba television 6 years old
Samsung 42" rear projection cuts itself off after only a few minutes. It will do this 4 or 5 times and then will stay on most of the time.
Comment by Juliemac2005, posted on May 08, 2008
I have the same problem i have a JVC and it turns on and off on it's own all the time. It will sometimes stay on for awhile and then it start just turning on and off.
Comment by rvillalvag, posted on Apr 14, 2008
I have the same problem too. I'm not sure if it is a TV issue, though, because a couple of months ago, my desktop PC was doing the same thing. I think it may be a power quality issue (noisy voltage supply or something). It seems as if some sort of internal protection kicks in. I have contacted the power company and the apartment managers, but they don't have the required equipment to check for this. Any suggestions?
Comment by dslindahl, posted on Apr 13, 2008
30" slim fit Samsung every 15-20 minutes shuts off.
Comment by nervouss, posted on Mar 24, 2008
Same problem on a 27Inch Samsung CRT seems to be heat related, when it
turns off I can turn it back on and for a split second i hear sound
then turns off again, if I let it cool down I can turn it back on and
sometimes it stays on for hours other times for only a few minutes.
Comment by Guest, posted on Mar 24, 2008
Same problem on a 27Inch Samsung CRT seems to be heat related, when it turns off I can turn it back on and for a split second i hear sound then turns off again, if I let it cool down I can turn it back on and sometimes it stays on for hours other times for only a few minutes.
Comment by JETPLANE, posted on Mar 17, 2008
42" REAR PROJECTION SAMSUNG, CUT OFF BY ITSELF 4 OR 5 TIMES AND THEN WILL STAY ON FOR AN HOUR OR SO. YOU NEVER KNOW WHEN IT IS GOING TO HAPPEN. I NEED HELP!
Comment by Guest, posted on Mar 05, 2008
yes I have the same problem, i try to see if something wasent connected in the inside to see if thats the problem but it dident work so im asking you if you know what the problem is
Comment by assamad, posted on Mar 04, 2008
i have a samsung 50 inch t.v. and it turns off by itself, it might stay on for a couple of minutes then it will go right back off. After three or four times it will stay on . Why does this keep happening?
Comment by scorpionitty, posted on Jan 12, 2008
My tv turns off by itself every 2 seconds. After a long time of turning it back on it might stay on for a couple of hours. I read from "take"'s answer to check the cold solder points...What are these? Where can I find them? Thank you!
Comment by drknow223, posted on Jan 09, 2008
my tv turn it self off after about 3hr and must be unplug before it will work again. what do i nee to do ? 32pt81 s127philips
Comment by Guest, posted on Jan 08, 2008
My TV turns off by itself. How do you correct it?
Comment by Metz, posted on Jan 06, 2008
I have a GE 32GT720 32" TV chasis #CTC203CF3 with a manufacture date of 1999 in Juarez Mexico. The TV does turn itself off and back on and switching between the cable and VCR setting on my TV. It was doing this every 15 minutes or so. I would unplug the TV and let it sit for a while. When plugging back in it was good for a while then back doing the same thing. I left it unplugged for about 3 days. I then tried again and the same thing. I then took the back off the set and put the set on a table outside the TV bookcase. It ran fine for 5 hours, then back to turning off and on by itself every couple of seconds. My personal opinion is that the problem may be heat related. Perhaps there are broken solder joints on the board that have occured over time with the flexing of the board due to heating and cooling over time. Am I right? I would like a solid answer and solution to this issue if possible. I don't know about the timer circuit idea as this TV does not seem to have a built in timer of any type. Perhaps I don't understand the solution offered...more ellaboration would be nice.
Thanks.
Greg.
Comment by Guest, posted on Jan 02, 2008
won't turn on. Light flashes on for two seconds
Comment by cooljcookie, posted on Dec 31, 2007
i have a 6 yr old kid.her tv in her room is turning itself off 10 secs after i turn it on. i have a 54 'hat has been in the shop for three weeks for the exact same problem. i'm starting to think that my kid is fooling with the buttons on our tvs. how do i fix it? and what do i tell the repair shop who has my big screen?
Comment by kelt, posted on Dec 20, 2007
my tv also shuts off on its own and the picture starts flashing. any advice please its a tau 34 flat
Comment by Guest, posted on Dec 11, 2007
The problem is in the timer circut which turns the tv off.This is caused by a defective sleep mode which is defective. Solution is disable the timer circuit completly by by-passing it internally. In other words cut it out and jump across the timer.
Comment by walbush, posted on Dec 02, 2007
I am haveing the same problem with my JVC.Turns on for 2 minutes than off green power light flashs.
Comment by ub3rg33k, posted on Nov 12, 2007
tv shuts off by itself after 1-2 hours, have to let it sit by itself then it works again for 1-2 hours, really annoying when you watch a movie over two hours....
