Question about Ricoh FAX3800L Plain Paper Laser
How do you change the date and time on a Ricoh 3800L fax machine?
Can you give me specific instructions on how to change the date and time on a Ricoh 3800L fax machine? I do not have the operator's manual available.
  • 904 Answers
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Posted on May 29, 2010
Hello, I have a Ricoh 1160L Fax machine and I
my fax is ricoh1160L.This fax always one fault 'CRU fuse error'show the display
Jul 20, 2011 | Ricoh FAX1160L Plain Paper Laser Fax
How do you set the time on a ricoh fax 2050l
PRESS (FUNCTION)
PRESS (6)
ENTER (2222)
ENTER(91)
ENTER(YES)
CHANGE MONTH WITH (*) OR(#) KEYS
PRESS (I>) CURSOR RIGHT KEY TO MOVE CURSOR
CHANGE DATE WITH WITH KEYPAD
CHANGE AM/PM WITH (*) OR (#)
WHEN DONE PRESS (YES) THEN (FUNCTION)
Hope this helps
Nov 20, 2009 | Ricoh 2050L Laser Fax
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh Fax 3800L Error code
You cannot purchase one unless you are a Ricoh certified tec and have a Ricoh ID, or an authorized deal. Why are you asking about the LASER UNIT!
Apr 04, 2009 | Gestetner Copier
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
Dec 10, 2008 | Ricoh Aficio 220 Laser Printer
Ricoh fax/copy machine
Instructions for 1013F are as follows:
above the blue numeric keys 2/3 there is a button with a small box with 123 in it this takes you in and brings you out of the USER TOOLS MENU.
Press user tool button once...user menu on display
use right arrow key...press3x..Fax Feature..press ok
right arrow2x..ok
again right arrow2x.ok....DATE/TIME on disply .ok
change then ok it once done exit by the 1st button you started with...USER TOOL BUTTON. all the best....
Mar 28, 2008 | Ricoh Aficio 1013F Copier
Date and time stamp
Here's the instructions for the date/time stamp.... I'll check on no. of pages and post that too.
Press the 'User Tools' key.
Use the right/left arrows until '2. Fax Features' is displayed.
Press the 'OK' key.
Press right/left until '4. Key Op. Tools' is displayed
Press 'OK'
Press '2222'
Press 'OK'
Press right/left until '7. User Parameters' is displayed
Press 'OK'
'1. Change' should be displayed - Press 'OK'
Now 'Refer Op. Manual: Switch 00 :xxxx xxxx' should be displayed; use the right/left arrow until 'Switch 02 :xxxx xxxx' is displayed (xxxx being a bunch of 1's and 0's).
When 'Switch 02' is displayed, the third digit from the RIGHT should be a 0. Press the '2' key, and that digit should change to a 1.
Press the 'OK'' key.
You should be back at the 'User Parameters' menu - just press the 'User Tools' key to return to the standby display.
Presto, try it out!
Please rate if this helps :)
Mar 26, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Nov 07, 2007 | Ricoh FAX3800L Plain Paper Laser
Print Report for Specific Date
I haven't found a way to print a TX report for a specific date. However there is a way to set the machine to generate an activity report at a certain time each day. Press "MENU" , 2-4-2, and you should be able to select the interval for your report by pressing the "OR" key (24 HOURS in this case). Hit "MENU" again and then enter the time you wish the report to print (24 hr format). "MENU", "STOP" and that should give you a report you can use each day.
Apr 23, 2007 | Brother IntelliFAX 2800 Laser Fax
Ricoh FAX3800L Plain Paper Laser Logo
423 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
