Question about Acer Aspire 5610-4648 Notebook
Ntldr is missing, this information is regularly coming even though I am trying to format my laptop acer 4715z with cd also when once it was it catched booting and started the process of formating after a few steps ahead it showed me that no hardware is available , kindly tell me what to do? now it is not booting with the cd which button or setting is required to solve the problem and able to format my laptop
  • 238 Answers
1. You must have a copy of "ntldrusb.zip" file.
USB: Right click the ntldrusb.zip file and choose "Extract All" Next>Next>FinishThen Insert your USB Stick into the working computer (remove any other USB sticks, and be sure there isn't anything on the USB stick that you want since we are about to erase it);
Double-click HPUSBFW.EXE in the ntldrusb folder;
Check "Create a DOS startup disk" and "using DOS system files located at" then press the grey button with the "...";
A box will come up asking you which folder to select, point it to the "dos system files" folder;
Press OK; Press Start; Press Yes; Let it run for just a few minutes till a new box comes up; Press OK; Press Close;
Open the "putonusb" folder, copy all the files, paste them onto the usb stick (just in the root of the drive, like E:\);
Eject the USB Stick; Remove it from your computer;
Place it into the computer with the "NTLDR is missing" issue, reboot it.
You will see the Windows 98 screen pop up for a second, then you will see a black screen with white letters prompting you to "replace boot sector of the drive C: (y/n)", press the y key;
It will go to a C:\ prompt, reboot the computer by pressing Ctrl+Alt+Del; (now go to step 4)
4. Put the new floppy/cd-r/usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
4. Put the new usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
f you get back into Windows again, you can change that "1st Try This" menu by going into Start > Control Panel > PerformanceAndMaintenance/System > Advanced tab > Startup and Recovery section, Settings button > System Startup; then change the "Default Operating System:" to the selection that worked for you, and change the box that says "Time to display list of operating systems" to however many seconds you want (usually 1 second). Click OK twice.
Posted on Dec 23, 2008
Start up says NTLDR is missing
http://www.tinyempire.com/notes/ntldrismissing.htm. read here lots of info for the NTLDR
Oct 04, 2009 | Acer TravelMate 2413LCi Notebook
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
Screen says NTLDR is missing.
hello friends..
Ntldr file is essential file in order to boot system...If it is missing then your system wont start..try to repair this file from XP/vista CD .. then problem will vanish
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hi I am doing a complete boot record format/delete on an "Acer Aspire 5315-2326" and when I try to install windows I get the error NTLDR is missing Press Ctl+Alt+Del to restart What is the problem I...
Ok, you deleted the boot record from your HDD, so it cannot boot now. You need to change the boot sequence to CD first, so you can install Windows from the CD. If the problems comes from the CD itself, maybe your disc is not bootable. Try another CD; if that fails, check your CD drive.
Apr 14, 2009 | Acer Aspire 5315 Notebook
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
ACER 4715Z crystal eye webcam is not working
if the appropriate driver installed then the camera option comes on the my computer windows at the bottom. it means the appropriate camera driver is not installed choose the right one from list or install it from the cd come with ur laptop
Oct 31, 2008 | Acer Aspire 5610-4648 Notebook
No post/blank screen
Do you have your Windows XP CD? Boot from that CD and at the prompt, press r for repair.
select 1 for windows installation and at the prompt type the follwing and press enter:
chkdsk /r
once complete (will take some time), reboot and you should be back in action
May 02, 2008 | Compaq NX6110 TFT XGA Notebook
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ntdetect.com D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Acer Aspire 5610-4648 Notebook Logo
538 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
