Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd640 code f05
Hose clear how do we find the filter?
  • Hotpoint Master
  • 3,463 Answers
The filter is located at the rear of the m/c behind the removable panel at bottom of m/c.
Remove lower panel and locate the large black hose at the right side, undo the fixing clip, and remove hose, be careful as there will be some water run out.
You will see the filter inside the hose, remove and clean, check pump is clear, refit hose, make sure you get it on properly,,and test for leaks.
Plz rate my solution.Thanks, and a merry xmas.
Posted on Dec 23, 2008
Stopped mid cycle with the code F 05 flashing up, it has been tried since with the same thing happening. Not sure what the code means?
F05 means pressure switch jammed on full.
You need to locate and clean pump filter, if not at bottom front of washer, then remove lower rear panel, remove large black hose on bottom of drum, remove and clean filter inside hose.
Fit back and test.
Mar 02, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint WD640G has stopped mid cycale and is showing the code? F O5 and will not complete the cycle
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 06, 2010 | Hotpoint Aquarius WD640 Front Load...
Fault code F05
If Hotpoint or Creda,
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code f05 flashing, what is this and how serious?
Error F05 means the pressure switch is jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it...
Error code F05 means pressure switch jammed on full.
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Thankyou.
Jan 13, 2010 | Hotpoint Aquarius WD640 Front Load...
F5 flashing and machine wont empty help
Do the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.Reassemble, and test.
Thankyou.
Dec 29, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Fo5
f05 means a blockage usually. check the drain hose is clear and there may be something in your filter or pump.
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd 640
Error code F05 indicates that the water level switch is stuck in the closed position, this is probablly due to a blocked filter or pump.
To gain access to the pump and filter, remove the lower rear panel of washer, locate and remove large black hose fastened to the bottom of tub.
Remove filter inside hose and clean, check inside pump for any blockage or restriction, and make sure the plastic chamber is clean where the small plastic hose is fastened to, as this goes up to the water level switch, and can sometimes get blocked.
Refit filter and hose, making sure it is securely on and fastened, and test, if fault still persists, then you will probably neeed to fit a new water level switch, or preesure switch as it is usually called.
Please rate my solution to your problem.
Thankyou.
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
218 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
