Question about Microsoft Xbox 360 Console
NAT restriction When I play my X box 360 online sometimes depending on what game I get a "NAT Restriction" comment. I think it is a problem with my router but not sure. Does anyone have a solution?
  • Anonymous Mar 21, 2009
    It wonnt go away, you need to change some settings
    Problem Solver:
  • 10 Answers
Your internet connection is not strong enough for the xbox live sevice... it may be week and have short connection failures, causing it to say that, try pluging directly into your broadband instead of using a router
thanks, Domo
Posted on Dec 24, 2008
How do i change my nat restriction
Try resetting your router and or modem and then restart your Xbox. If that doesn't work I'd suggest calling your Internet provider for more help.
Nov 12, 2011 | Belkin Basic Wireless Router
How to unmute yourself on xbox 360
Hi there I can sort understand what you mean and I think this is the answer. If you cannot be heard normally in chat when online even though your mic is turned on or you have made sure that in preferences, you went in to audio settings and made sure you were not on mute? My guess is your having issues with your NAT settings as this can affect you chat settings when online. For example, xheck your NAT status and if it is MODERATE or STRICT then this is why. If you NAT is OPEN then it is because the players you are playing with have a NAT issue. MODERATE and STRICT NAT's will limit what you can do online, including chatting.
Hope this answers your question :)
TEEMAN
Nov 01, 2011 | Microsoft Xbox 360 Console
I have black ops but i cant join when i play zombies but online can i join
The only reason why I think you aren't able to find any games is because your Nat is closed. to open your NAT try this link. Also try to have your search preferences on fastest.
Feb 07, 2011 | Video Game Consoles & Games
I have a ZyXELPK5000Z router. How do I get the NAT open? I want to do this in order to play more interactive games with my friends online. My NAT type is strict, and I know this because I test network...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 15, 2011 | Computers & Internet
Better online gameplay xbox 360 open nat type
Hey to open your NAT log into your router and look for a setting called DMZ enter your xbox IP (usually starts with 192.168.1.?) into the DMZ box and enable it.
Good Luck & Game on!!! :)
Jan 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
2 xboxs in household only 1 can go online at once
You can contact Xbox regarding that as they have a certain restriction with connecting 2 XBOXs to XBOX live at the same time.
Apr 11, 2009 | Microsoft Xbox 360 Console
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Network address translation [nat]
Depending on your router, you will need to go to its setup. Go to the link where you can forward ports. (Port range forwarding). Then you will enter the information that you recieved when you called Xbox Customer Support. (Call them for it, it is free) Enter the information and you will be good to go.
Jun 23, 2008 | Microsoft Xbox 360 Console
Un restrict my nat please
Login to your router by typing 192.168.1.1 in an open IE window you should be asked for user name and pass both are admin now find the Security tab, then the Firewall section. Uncheck "Filter Internet NAT Redirection" and click on Save Settings.
Go to the Administration tab, then the Management section. Set UPnP to Enable. Click on Save Settings. Your router will reset and now it will work for the 360
May 01, 2008 | Linksys Wireless-G WRT54G Router
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
Microsoft Xbox 360 Console Logo
454 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
