Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
USB Connection I have had this 8" Pandigital photo frame for a year now. Hasn't been turned on for months. It works, however, I'm trying to delete the pictures/music on it, and download new. When I insert the USB cable provided nothing happens. I've tried 3 different computers. I've done step by step on their instructions. They say sometimes it takes several minutes for your computer to recognize the hardware. Nada. Any suggestions?
  • amanda349 Jan 07, 2009
    I'm running Windows Vista and also can not transfer pictures from my PC to the frame. It recognized something was plugged in to the usb port when I first plugged it in because it downloaded drivers. However, it shows no removable storage device in which to transfer the pictures. I wonder if it doesn't work on Vista?
  • 423 Answers
Hi Amanda and Lisa. Are you making sure the picture frame is off BEFORE you plug it in to your computers? Make sure you:
Turn it off before pluging it in, then plug in the USB cable. Now you can turn on the picture frame and you should see the frame's memory and any SD cards you have plugged into it in the removable drives section.
Let me know if that helps. If not let me know, and thanks for coming to FixYa. If you're happy with my answer then don't forget to rate it appropriately.
Rob
Posted on Feb 21, 2009
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pics from Computer to Pandigital
If you use iPhoto to put photos on the frame, you'll end up with a bunch of extra files on the frame that say "Unsupported Format". This is file management data added by iPhoto.
When you connect the frame via the USB cable, it should just appear as an icon labeled "Pandigital" on the desktop. You can just drag and drop your photos onto this icon.
Jan 19, 2010 | PANDIGITAL 7" Digital Photo Frame With...
Removing certain picutes from the frame
Hi, if this is a Pandigital frame, go to the manual pg.9 and follow instx under"Delete Photos from Internal Memory.
If it is another brand,try: on the Home screen menu,select Manage Photos( Make sure you do not have a Flash memory,camera card,usb etc connected to the frame!) and, under the Delete select the individual
photos to be deleted.
Hope this helps, but,I'm only familiar with the Pandigital
Dec 21, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Wanted to erase a single picture, accidentally erased all. Now, computer not recognizing frame, asking me to format removable disk before I can use it. Unable to reinstall. Before, computer recognized...
Yes, that's because you have deleted the files. The frame will work just fine. You can can rename 'removable disk' to PANDIGITAL but it doesnt really matter.
All you need to do is copy the images and it will show up on the frame.
Jun 09, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Nov 25, 2008 | PANDIGITAL 7" Digital Photo Frame With...
I NEED A INSTRUCTION MANAL
I got my digital "pandigital frame last year and lost the instructions. Can you tell me how to download photos from my PC via Usb to frame?
thanks Deejohn2127
Oct 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
541 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
