Question about Sharp R-1750 Microwave Oven
Microwave works; LCD touch screen is all gray/blank
If I leave the microwave unplugged for 24 hours the touch screen will work for about another 24 hours and then it "grays" out. The microwave still works (I can remember where the buttons are supposed to be) but is useless without being able to see the screen. Any help you can provide is much appreciated.
  • Anonymous May 04, 2009
    I have a simular problem, the display was bizare, but could sort of be used, for a few hours and is now grey and nothing functions.
    Is this a replacement part you can send me or do you need the old one to repair?
  • Sharp Master
  • 9,125 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week with a one year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 25, 2008
Testimonial: "The info and product supplied by Prototech was extremely helpful and easy to install. My microwave was running perfectly in a matter of minutes."
My microwave turns completely off... Touch pad and lights inside... I have to wait 10 seconds to 10 minutes and then it turns back on and will ask if you want to set the clock. Sometimes it will let me...
Hi Ben,
This has got to be an intermittent power to the control PCB problem. The control board asking to set the clock means that the CPU has been reset by losing power. First, make sure that the problem is not the outlet by plugging in a small lamp or digital clock to see if it works intermittently or resets. Leave it plugged in for at least 24 hours.
(If using a lamp, put in a small 20 watt light bulb or CFL).
It could also be a bad connection to or at the fuse holder in the microwave oven. If all of the wiring and connections look good, it's most likely a bad connection on the control PCB probably around the transformer on the board. Be careful.......
Oct 22, 2013 | KitchenAid KHMS2050SSS Microwave Oven
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
Aug 12, 2011 | Sharp R-1750 Microwave Oven
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try it.
Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
LCD not working on microwave
The is a prone problem accross the Sharp range where the LCD fails. They can be repaired but this can be quite costly.
Feb 17, 2010 | Sharp R-370E 1000 Watts Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
Buttons dont work on danby microwave
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn;t working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Screen/ keypad seem to be locked
Sounds like the child lock has come on.
This addressed in your owner's manual. but if for some reason you don't have your owner's manual, you can download Maytag owner's manuals and installation instructions here.
Just enter your full model number.
If it's not the child lock,
I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Dec 23, 2008 | Maytag MMV1153A Microwave Oven
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Sharp R-1750 Microwave Oven Logo
252 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
