Awo/d 4305/s clean pump light on
The light on front of machine comes on can i do myself ??cant find manual for this can you send it on to me by email to patrickscully1@eircom.net
cheers
Pat
  • 3,037 Answers
Hello patscully
the manual can be gotten by calling 1-866-698-2538 and they can send you one through email.
bestdarngood
Posted on Dec 23, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try:
  • clean the filter, sump, impeller, pump;
  • remove screws of access panel located on the lower right front;
  • with access to the pump and others, clean the filter and others;
  • a bit of a messy job, pls make sure of paper towels ready;
  • thereafter, allow to air dry, or force dry with a ventilator/fan forcing air inside;
  • alternately you can use a can of compressed air, a compressor or a vacuum/blower;
  • a not so technical trick is to lay the machine on its side after the cleaning to ensure that water on the sensors, floats and everything else drip/drain away.
Sorry, no free manual. Should you still be interested, pls click here.
Good luck and Thank you for using FixYa. Happy Holidays.
    President:
  • 373 Answers
We could not find free online manuals but here is a link that might help you out.
http://www.manuals-in-pdf.com/AWO/D%204305/S-p-931033.html
  • 495 Answers
Go to this site for your manual, you can directly see its contents
http://www.whirlpool.com.hk/sc_upload/images/awo_d042_usermanual.pdf
    President:
  • 2,110 Answers
  • 700 Answers
Here's the link that you requestd sir.=http://www.whirlpool.user-manuals.com/whirlpool-c-6.html?page=343&sort=5a tbhanks for usein Fixya
  • 15,935 Answers
    Sergeant:
    Novelist:
  • 327 Answers
Http://www.applianceaid.com/washers.html click this link.for the repair details. and for for the parts and manuals
www.repairclinic.com
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awo/d 4305
If you're talking about the drain pump clean out trap, the following link explains how to check it and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
This is the only "filter" on this washing machine. If you need service information, the manufacturer normally places technical information inside the appliance behind the bottom panel under the door. Look inside and there should be a tech sheet taped to the inside of the cabinet walls, or inside the bottom panel. I hope this helps you. Let me know if you require addtional assistance.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
