Question about Dell Laser 1720 Printer
Replacing Dell Laser printer cartridge 1720
I need some help to replace the cartridge that I purchased. The old cartrdge is out of ink.
Thank you very much!!
    Genius:
  • 1,605 Answers
Open the front cover by pressing the button on the left side of the printer and lowering the cover.
Press the button on the base of the toner cartridge assembly.
Pull the toner cartridge up and out using the handle.
Unpack the new toner cartridge.
****Rotate the cartridge in all directions to distribute the toner****
Install the new toner cartridge by aligning the white rollers on the toner cartridge with the arrows on the tracks of the imaging drum and pushing the toner cartridge in as far as it will go. The cartridge clicks into place when correctly installed.
Close the front cover.
Posted on Dec 23, 2008
My printer doesnt make any print at all.
Can you copy a document under the glass? B&W and color?
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Aug 14, 2011 | Dell 924 All-in-One InkJet Printer
I just bought a new cartridge for my 1720 Dell printer two months ago and now the cartridge smears and leaks ink. What do I do?
The first step is to replace your cartridge to see if that cures the problem with your printing results. If you cartridge is leaking ink it definetly needs to be replaced. There really no way to fix a cartridge from leaking so-to-speak. There would be a risk of damaging your printer by fixing your cartridge without the assistance of a technician.
I hope this helps you,
Regards,
Nico
Jul 05, 2011 | Dell Office Equipment & Supplies
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
Replaced ink in printer with generic ink cartridges and error message 1203 came up.
A person might notice that buying new, name brand, ink cartridge for printer rapidly becomes quite an expenditure. Nonetheless, there are quite a lot of different methods to find the equal quality standard for a alot lower price. Your primary options are: name brand (OEM) ink cartridge for printer, matching generic ink printer cartridges or remanufactured ink printer cartridges.
When you are purchasing a replacement photo printer cartridge, consumers do have choices. It’s frequently assumed that shoppers are required to buy the expensive, name brand, cartridge for laser printer from the manufacturer, or the service contract will become void. Their belief merely is not correct. By law, the use of compatible replacement inkjet printer cartridges does not render null and void the printer makers guarantee. In truth, you can choose to get less pricey compatible cartridge for laser printer, or remanufactured cartridges, often with a realized savings of between 40% and 75%. All chief ink laser printer cartridge brands have matching versions, including IBM, and Xerox.
Name Brand Inkjet Cartridge for Laser Printer
Nearly all major makers of laser printers also create the replacement inkjet printer cartridges that are best matched for their particular laser printers. This option is ordinarily the most expensive, and in a lot of situations it is the lone choice available if you happen to get a new laser printer whose producer implanted computer chips in the ink printer cartridge. The point of this chip may possibly be to regulate the color ink flow, limit the cartridges use, or to standardize the cartridge in alignment. Nevertheless, if you pick out a similar, or remanufactured, cartridge for laser printer, it might not be able to interconnect with the laser printer and may harm the laser copier or cause it to quit working.
Comparable Generic Inkjet Cartridge for Laser Printer
When thinking about purchasing an ink printer cartridge for your laser printer, the key aspect you must to bear in mind is the price. Buying a brand new ink laser printer cartridge will be based upon how much you are prepared to give. You can buy a new brand name cartridge for printer, or you might purchase a new compatible (generic) ink printer cartridge. Both types of ink printer cartridges might provide you with the same quantity, quality and performance you insist on from your printer. The major difference is in cost: a brand name ink printer cartridge might easily cost nearly twice the price of a compatible cartridge for printer.
Compatible (generic) inkjet laser printer cartridges are made to meet OEM (Original Equipment Manufacturer) specs. These makers usually set very lofty standards of dependability and quality and also provide high quality results, regularly exceeding the quality specifications established by the OEM. These cartridge for printer are produced with new parts and are a lower priced option to costly name brand ink printer cartridges.
Buyers might also be surprised to see that the generic comparable cartridge will publish the same amount of, or more, pages than the original OEM cartridge. Largely, this is since certain original OEM ink laser printer cartridges are not filled all the way up. In this situation, a compatible ink cartridge for printer could give you twice the advantage: it reduces your price per cartridge and cost per page by printing additional pages
Dec 27, 2009 | Dell 926 All-In-One InkJet Printer
Laser 1720 printer leaking ink on the right hand help its a dell
Look at the toner cartridge.
There is a small plastic locking collar on the end of the spindle of the rubber Developer Roller (it's this that carries the toner to the drum). I'd bet that this locking collar is loose, misplaced, or missing.
Leaking toner on the right of the printer is usually caused by this.
The other possible cause is a partially detached seal underneath the Developer Roller.
May 04, 2009 | Dell Laser 1720 Printer
Toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Mar 05, 2009 | Dell Laser 1720 Printer
No printing
DEAR SIR I REPLACED THE DELL INK JET CARTRDGE.TAKING THE OLD OUT.AND SNAPPING THE NEW BACK IN.THE BLACK AND COLORED NAME PLATE FACING ME.AND WHEN I HIT PRINT.A SIGN COMES UP.SAYING CARTRDGE STALL.WHAT DO I DO TO GET IT TO WORK. AL
May 28, 2006 | Dell A920 InkJet Printer
Dell Laser 1720 Printer Logo
216 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
