Hooking up a dvd player
I have a Sylvania TV and am trying to hook up an Oritron dvd player. Both are several years old and the remotes that I have are - one for the dvd player and a remote for the tv as provided by Direct TV.
We have hooked up the yellow wire to video on both the dvd player and the tv as well as the audio white and yellow.
We have switched the Direct TV remote to tv and turned either channel 3 or 4 and have attempted to play a dvd - nothing happens.
My husband and I are both extremely frustrated and need some clear concise instructions on what to do. We are both sure that we are missing something extremely simple but cannot figure it out.
Please help before we throw everything out the window (ha! ha!)
Thank you.
Sue
  • 7 more comments
  • Sue Edwards Dec 23, 2008
    There is no tv/av button on the remote.
    I'm still needing assistance - can someone please help?
    Thank you.
    Sue
    The remote from the DirectTV has an AV1 and AV2 position at the top. I've switched the switch to one then the other and nothing happens.
    Thanks.
    Sue
    10-4 on the yellow, red and white cables. We have ensured they are plugged in correctly.
    When we change the channel to 3 or 4 with the Direct TV remote-still nothing happens.
    Sylvania TV set to Video 1 or Video or Video in or Aux not Ch3 or 4 - How do I do this?
    Thanks,
    Sue
    O.K. - I know I'm sounding stupid - but I want to make sure I have the steps accurate.
    I plug in the dvd player to the proper slots for the yellow, white and red plugs - then with the Direct TV remote still in DirectTV mode, I hit the menu button on the front of the tv to change to AV mode - then insert a dvd in the player and it should work?
    If that is correct, once I hit the menu button, what do I then click on to change the mode? Is this done with the remote?
    Thank you.
    Sue
    If that is correct -
    Thank you for the Sylvania Manual - the only problem is, the manual is for a TV/DVD unit. I'm trying to hook up a separate dvd player to my tv.
    Back to my last question - if my procedures were in the right order, what do I do to change the tv to AV mode? I know it was indicated I hit the menu button on the front of the tv - then what? And this is with the tv in Diect tv mode - correct?
    Thank you.
    tborn6 - now I'm more confused then ever. Please take me back to basics so I can understand the entire sequence from start to finish.
    Sorry to be such a bother - but I'm not electronically inclined and neither is my husband - so I need step by step instructions in easy to understand format for us to follow.
    Thank you.
    Sue
    Please, someone read the thread and my last comment about needing step by step instructions. I would appreciate it.
    Thank you.
    Sue
    The remote doesn't have anything like that.
    I do not have the remote for the Sylvania TV any longer - do I need to get a universal remote and program it for the tv?
    Is there no way to get this set up easily? We've been working on this for two days and I've spent half a day working on this thread and still have been unable to get a clear concise step by step response.
    Thank you.
    President:
  • 1,179 Answers
Try the AV1 or AV2 settings on the TV. See if you get the DVD welcome screen using one of these settings. Hope this helps.
Posted on Dec 23, 2008
  • 67 Answers
Doesit have the coaxil hookups on the back of both if so it has to be hooked up with that not the red yellow and white i had the same problem
hope this helps
  • 395 Answers
Http://www.sylvaniaconsumerelectronics.com/support/connection.html and pick rca connection
turn your tv to the channel below 2 it should say aux 1 or aux 2
  • 19,396 Answers
Sylvania TV set to Video 1 or Video or Video in or Aux not Ch3 or 4 - How do I do this?"
With the originalremote, if you cannot access tv setting menu, and have no input selection,the replacement remote is of no use.
You can buy an original replacement here
sylvania replacement remote - Google Product Search
    Top Expert:
  • Televison & ... Master
  • 83,081 Answers
U need the original remote so u can access the TV's video menu, u can not do this from the remote u have which is a unversal type, turning the TV to channels 3 or 4 is of no use because the video (yellow RCA Cable) is dedicated to the video input option on the TV's original remote
    Genius:
  • 1,199 Answers
YOU NEED THE REMOTE FOR THE TV AND NOT THE ONE TO THE DIRECT TV BOX!....ON THE TV REMOTE HIT INPUT SELECT BUTTON oOR AV BUTTON!
  • 916 Answers
Try pressing the tv/vcr button on your remote sometimes it will be labeled either input tv/vcr or a/v. Press that or see if there is a button labeled with one of those on the front of the tv.
  • 4,889 Answers
In most old TV sets and DVDs you just have to load the disc and press the "Play" button to put the device into DVD mode. Not sure if it works for your but its definitely worth a try. Please rate it if it worked.
Thanks for using Fixya.
Sai.
  • 700 Answers
You have to turn the remote back to the directv setting dur to the fact that its controlled by direct tv. the dvd has to go directly to the tv only. you shuld be able to do this . run it from directv-dvd-then tv . T=hanks for using fixYa
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link to refer the manual. Read the page 10 to 15.
thanks
good luck
    Genius:
  • 2,035 Answers
The DVD is played AV mode you need to tune the tv in av mode and play the DVD .You need to choose the mode from the front menu button in the tv as you don't have the tv remote..
good luck..
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls verify connections:
  • Video OUT of DVD to Video IN out Sylvania TV (yellow);
  • Audio OUT of DVD L/R to audio IN of Sylvania TV (white & red);
  • Sylvania TV set to Video 1 or Video or Video in or Aux not Ch3 or 4;
  • Sylvania TV set to Ch3 or 4 when watching Direct TV.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 23, 2008
    If the above connections have been confirmed and pressing on the Direct TV remote AV1 or AV2 does not change the TV from a channel to AV mode, then the remote does not activate fully some of the TV's functions including shifting from regular channels to AV mode. Might you pls check if on the control panel of the TV, there are manual controls to perform switching to Video 1, AV1 or Video mode?
  • Louie  Role
    copy you lima charlie.
    May I further suggest:
    • turn on/power up only the DVD player and the TV;
    • before anything else, play a known good DVD disc on the player, even if you could not yet see/hear it yet;
    • press the the AV button or Source or Video on the Sylvanias' front control panel not the MENU button and not on the Direct TV remote.
    • thereafter you can try figuring which of the Direct TV buttons will activate/deactivate the Sylvanias' AV mode.
    TNX.
  • 15,935 Answers
You have to change the INPUT on the TV.
Usually it is AUX or Video/TV button on remote. Some older TVs you actually go one station BEFORE #2 and it is the INPUT. Look on the remote for TV/DVD button or similar.
  • blueextc3221
    blueextc3221 Dec 23, 2008
    Audio should be white & red BTW
    President:
  • 2,110 Answers
Change the TV input to A/V from TV remote..
    Sergeant:
    Novelist:
  • 327 Answers
Is there any ---tv/AV--- button on your tv   remote press that button to go to the dvd mode and then check out.
How do i connect my rcr remote to my oritron dvd player?
Your RCA remote may not have a code for your Oritron DVD player. You may have to try another remote.
Aug 01, 2014 | RCA RCR-4258 Remote Control
Hooking up dvd player
I searched everywhere i could think of for a manual or a diagram of the back of the player with no luck - any chance you can post back a photo of the back of the dvd player, then we can easily talk you through what to connect to what and what cables to use. :)
Jun 27, 2007 | Oritron DVD600 DVD Player
Tip
Oritron DVD600 Region Free Fix
Oritron DVD600 DVD Player Region Free Fix
Would you like to unlock your Oritron DVD600 DVD Player to Region Free?
Follow these steps to unlock your Oritron DVD600 DVD Player:
  1. Press the Menu button on your remote control.
  2. Using your remote control, enter the code 1, 6 and 7.
  3. Press the Mute button on your remote control.
  4. Press the Okay button on your remote control.
Your Oritron DVD600 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Oritron DVD600 DVD Player
I have been having problems hooking up my truflat RCA TV to my Sylvania dvd/vcr player. the cable plug is hooked up to the tv and the dvd plugs are hook up. What else should I do?
Hello
If you have connected the audio video out of DVD to audio video in to the TVs front panel; what else to do?. Power up both the devices, goto the menu option of your tV, set it to vidieo mode, open the tray of the DVD by it open-close button, put a dvd disc in, push open close button of the DVD again, take the remote control of the DVD; select the chapter you want to see, sit back easy and see the recordings on the disc. That is all. OK.
Feb 12, 2011 | Sylvania 6419TC 19" TV
Hook dvd to tv with direct tv dvr
does your dvr have componet video connections
May 31, 2009 | Oritron DVD600 DVD Player
Old TV and old DVD player
Make sure your TV is "tuned" to the proper input. To change the input, change the TVs channel below 02, find the "input" dialoge on the tv's menu, or press the "input" or "video" button on the TV or Remote.
Repairing a 20 year old VCR (By chance a BetaMax?) is not worth your time. Replace it with a $60 DVD/VHS combo unit.
Mar 12, 2009 | Televison & Video
I have a Oritron DVD player,Need Dirctv remote Code for DVD Playe
Try calling Oritron. If you are lucky, your DVD player is simply a rebadged model from a major manufacturer and there may be other codes they can suggest.
Dec 05, 2008 | Directv RC23 Remote Control
Dora Tv & Dvd
How are you connecting the two? A/V input jacks? Are you selecting that input (line 1, line 2, etc...)?
Sep 12, 2007 | Emerson Dora The Explorer DVD Player
Help!!Hook-Up DVDvideo to TV
There are two options. If you already have a VCR, run the RCA cables(red, white, yellow; one audio OK) into the inputs at the back of the VCR and then the single "plug for cable" from the VCR out to the TV's input. You can also buy a device at any electronic store, and even at Big Lots, which does the same, but without the VCR, just the inputs and outputs.
May 28, 2007 | Oritron DVD600 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
