Question about Sony KV-36XBR450 36" TV
Channel jumping While watching programs from air the screen displays the lower half of a frozen image that was last seen. The top half of screen displays a frozen image from another channel. Audio maintains original channel reception without interruption. While watching DVD the display goes black. While watching air program through hd reciever picture freezes and turns to purple duo-tone. What to do?
    President:
  • 1,284 Answers
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Posted on Apr 12, 2007
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Element Plasma image overlayed with ghosting
if the images of the previous channel what you are looking it is the pdp panel problem plasma display -pdp panel
Nov 05, 2013 | Element Electronics PLX4202B 42 in. Plasma...
I am trying to reinstall a Magnavox HDTV converter box on my television. and when I get top the part in the several instruction sites I've visited after 'turn on box' everything goes in the toilet. My...
Which model do you have? The EPG is an electronic program guide. The Magnavox TB100MW9 digital to SD analog converter works as given below. The manual is available here: http://dtvconverterboxes.blogspot.com/2009/05/magnavox-tb100mw9-owners-manual.html . (It's embedded in the reviews.)
Press Setup, then go to Channel amd then AutoScan. (Use the up/down arrows to highlight and then press OK to advance to the next menu.) The channel option also lets you add or delete channels if you know the channel and sub-channel. If you see "No signal" make sure you have the best antenna for your area (distance to the stations), have the antenna pointed at the transmitter, and do not have any tall buildings and trees to block the signal. Make sure you have good cables (no damage to the ends or the insulation) and that they are connected well to the correct terminals. Amplifiers can bring in a weak signal but can be damaged by a surge over the antenna.
The other buttons: Display turns on the banner for the current channel. If this data is being sent, then it will provide the Program Title, rating, audio language and other information. (I've seen stations that give incorrect information or just a placeholder.) Still: Pauses the current image on the screen (the converter doesn't record anything so when you resume the program, it will jump to the current broadcast).
I hope this helps.
Jan 26, 2011 | Televison & Video
I have a Panasonic PT-53wx54 HDTV. The text on the ticker on the bottom of the screen that stations like CNN run is not completely visible, only the top of the letters show as they travel across the...
The set is probably in the wrong display format for the channels you are watching. Look through the setup menus for "Display format" or "Display mode". You need the menu that sets the picture for "480i", "720p", "1080p", etc. Set it for 1080p and see if that fixes it. The lower settings won't show all of the lines for a 1080p picture; they are used for old-style analog video or low-bandwidth broadcasts.
Disclaimer: this is general information and may not apply exactly to your particular model. You may still have to find your owner's manual or download a copy to find out how to correct the settings.
Oct 06, 2010 | Televison & Video
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Oct 22, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Sony KV-36XBR450 36" TV Logo
192 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
