Question about NetGear DG834G Router
Password protect my router from others
I have the 54mbps wireless ADSL2+Modem Router DG834G and i was wondering if anyone could tell me how i password protect or encrypt my internet so no one else can access and use it without my password.Emma
  • emma
    emma Dec 24, 2008
    Thankyou for that,it worked well but how do i now allow my partners ps3 to connect,i went into set up access list and added him but he still cant connect to it,please could you help again,merry xmas,emma
  • Anonymous Jan 22, 2009
    i wnt to change my password lol
  • 104 Answers
Hi … There is more than one way to set up wireless security on this router. I’ll try and help with the manual method, which is the similar for most routers.
Important: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
You have probably done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
You should see a popup box. If you have not changed the password, enter username: admin and password: password
This should bring up the configuration screen/user interface.
2) Change the router password.
If you haven’t set a password, this is a good place to start. Go to Maintenance > Set Password. Set and confirm a new password. Click ‘Apply’ when finished.
Make sure this password is not easy to guess, or someone could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Wireless Settings. You should the Wireless Network Name or SSID at the top. Change this from the default, NETGEAR, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘Apply’ when finished.
4) Enable encryption
Still in the Wireless Settings menu option, you should see the Wireless Security Options section. You have a number of options for encryption. WPA is safest....I would pick WPA-PSK, though strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start off.
You should see one or more new options pop up. I would leave most settings at the default. However, under Pre-Shared Key/Network Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key or passphrase). Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Dec 23, 2008
  • eecom Dec 27, 2008
    Hi, thanks for the feedback!
    The PS3 may be automatically set up to connect to the network under its old name (SSID) and unsecured settings, so will not find it. To regain access to the network, your partner needs to access and adjust the network settings on the PS3. See this page for help with this.
    If it does not help, please repost with this new problem if needs be - I'm no PS3 expert, but am sure someone else will be able to help. :) Thanks and all the best.
I forgot my netgear modem router password
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Dec 25, 2010 | NetGear : DG834G 54Mbps Wireless ADSL...
I am using dlink wireless router. How can i restrict unauthorised users accessing net through my connection?ADSL2+router
By using your wifi security.
Log on to the router and turn on WPA2 security, choose a password, and you should be ok
Sep 23, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Why does my internet keep disonnecting
Install Router Commander. This program can optimize router settings and speed up your internet connection. The other good thing about this program it protects router from overflow and you connection did not disconnects.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i password protect my router from outsiders connecting
Hi, check out the support pages here:-
http://kbserver.netgear.com/products/DG834G.asp
Select your model (v3,v4,v5 etc) then look at the setup pages. Set your security to WPA rather then WEP as this is easily crackable, and with WPA you can choose the password. You should also change the routers admin password to be extra safe.
Let me know if you need anymore help.
Dec 23, 2008 | NetGear DG834G Router
Can't get my netgear wireless router connected again to the internet
There is a small reset pin hole on the back where the power plugs in. Use a pin and push it in for 30 seconds, while plugged in. This will reset your router back to the factory settings. When done, just run the install disk again.
Jun 01, 2008 | NetGear DG834G Router
Netgear setup
You have to connect to the router with ethernet to get onto the configuration page. what i think what you have to do is to get a lan card and install it.
Oct 16, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
183 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
