Question about Whirlpool GGQ8831L Gas Dryer
No response when start button is pushed
Light does not come on when you open the door
wall outlet is okay
shut door firmly, spin timer dial, push button--nothing
Just like dryer wasn't plugged in at all
  • Anonymous Jan 05, 2009
    light does not come on when you open the door
    wall outlet is okay
  • 640 Answers
Check you door switch make sure it there and not broke off,,,onthejob
Posted on Jan 06, 2009
My GE Dryer Model #DJXR433EG1WW will not turn on. It will not turn on and the dials don't turn right.
It sounds like your door switch is not closed. This switch has to be closed in order for power to be available at the start button. Open your door and manually push the button in and then carefully push your start button provided you have turned the timer on. If you are handy you can by pass and jumper out the door switch. The other possibility is if you can hear the motor quietly start when you push the start button your belt may have come off the pulley and the motor is just spinning.
Oct 12, 2014 | Dryers
Dryer stopped with 30 minutes left on the timer, I reset the timer and pushed the start button nothing happened I opened the door the light came on shut the door tried to start again and again nothing. it...
its not the timer its your thermal fuse located in the back of the dryer behind the panel if not there it will be in the front at the bottom behind that panel. Its usually placed on the vent outlet housing.
Dec 17, 2010 | Dryers
I have a Tork 806A timer, but no instructions on how to set the on/off cycles.
Tork 806A: There are 6 outlets. Bottom two outlets are always on. Top four outlets controlled by timer all four outlets turn on and off at same time.
Load: Total load on all 6 plugs cannot exceed 1500 Watts, which is typical for 15A circuits. Indoor wall plugs are 15A. Don't add more load to timer than you would put on ordinary wall plug.
Set Time: Rotate dial clockwise to set time. On face of dial, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} push tabs down to turn on loads, pull them up to turn off loads.
Reset: Timer has reset button in top left corner.
Jul 25, 2010 | TORK Digital Interval Timer Ssa100r-24
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
Dyer will not start-Start button seems to be the problem
This may be your timer or your start switch may be bad. Hope this helps!
Aug 14, 2009 | KitchenAid KEYS700LQ Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Washing machine shuts down in spin cycle
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground.
Nov 29, 2007 | Washing Machines
Whirlpool GGQ8831L Gas Dryer Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
