Question about Kenmore 49072 / 49074 / 49079 Electric Single Oven
Oven light is stuck on
Our oven has a very heavy door so when you close it, it usually pulls to w/ a bang. The oven light would sometimes stick on but if we "jiggled" the switch a little it would go off. Well, now our oven light is stuck on and is keeping the oven warm. There is a clicking noise when the light button is on (or off, I can't tell which is which right now) and the switch is jiggled. The bulbs are behind a grating so I haven't been able to remove them. If I do pull the bulbs out and the switch is in on position, will I burn anything up? Do you have any suggestions for how to best get the light to go out? Thanks!
  • 87 Answers
Replace the door switch.
Posted on Jun 10, 2007
What does f13 mean
if you mean on a whirpool washer it is the door connection circuit. Try banging the door on the right to manually unlock it. Once open check that the hook is aligned with the door lock. If you have switched the machine off then all the lights may have gone off. Leave for 20 minutes then switch back on and hold the reset button for at least three seconds. If this works and lights come back on try a speed wash to check every thing is okay.
Sometimes if the machine has been knocked or the door not closed correctly this will happen.
Nov 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
ECD230 dacor oven, th bottom door isn't sealing all the way, you can feel heat escaping. Is there an adjustment to make?
jenn air had some issues with there hinges wearing fast in prior years on there ovens and then you have the ones the kids use as a trampoline sometimes or the heavy turkeys laying on the door while it is opened... there really isn't any adjustment for the door the hinges bolt inside and are held in one place by a few screws ...they are replaceable as welll as the door gasket on the unit... hope this helps you out some... alot of the appliance sites out there will be able to assist you with parts such as www.sears.com then click the parts direct link up top have your model number usually inside unit either on door or inside where door closes... some units between door and cabinet area... good luck to you
Jan 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
My ge cafe gas oven light won't turn off
The switch which activates your light probably is stuck/broken in the on position.It should be similar to a refrigerator where you can see a small rod sticking out,or something that sticks out of the completely flat front of your oven with the door open.Sometimes there is an access panel,sometimes the whole panel comes off.The screws should be noticeable,almost flush on the front.Sometimes they are covered with a cap for appealing looks.Those just pry or unscrew off.
You will have to order the part.Even if it is expensive,there probably is a $50 minimum for a repair center just to show up.Then labor,20% minimum parts price markup also.Greg Pull the circuit breaker before messing with any wires.
Nov 17, 2010 | Ovens
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
I have modle 465 oven about 10 yrs old and it is a self cleaning oven. Anyways I preheated the oven 450 and the door locked and I can't get it opened.
the safety lock engaged, then got stuck, a common problem. try banging around the door with your hand and press and pull the door
Jul 10, 2009 | Ovens
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven Door Jen-Aire Single Oven won't shut all the way.
you have bad receviers probably. did you set anything heavy on it latley? sometimes you can realign the door by sticking a peicee of 2x4 between the door and the frame and closeing the door to pop the hinge out a little thatt sometimes solves the problem with out haveing to replace the hinges and the receivers
Jan 04, 2009 | Jenn-Air JJW8530C Expressions Collection...
Glass door drip marks
Since the manual doesn't tell you how do this, and the repair place can't either (other than a service call) I got a little creative without trying to take the whole door apart. First, un lock the hinges and take the door off, It's a bit heavy so be careful. Lay the door on it's back. Now find something long and thin ( a yard stick will do) drench a long cloth with windex and then slide the cloth and the stick between the glass, just make sure you hang on to the cloth so you don't get it stuck between the glass. This worked perfect for me, and saved a service call. Poor design, it should be simple to remove the glass, I guess the designer never cleaned an oven. Make sure you put the door back on correctly, othewise you will go nuts. Angle it in on a 45 dregee angle to the first notch. Then instead of naturally trying to close it up, pull it down slowly to towards floor to open up the hinges and then close it back up. Good luck
Dec 13, 2008 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
253 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
