Question about Hotpoint Ultima WF860 Front Load Washer
How to replace door seal of Hotpoint WF860 washing machine
I have the replacement seal but I can not work out how to release the existing seal and therefore fit the new one. Any advice please?
    Scholar:
  • 86 Answers
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Posted on Dec 28, 2008
Water is leaking from the door when machine is on. this is not happening all the time. the machine is a washer dryer WD860 (1600). I am not brilliant at diy but I would look at doing it as just seen how much hotpoint want to charge
Posted on Nov 11, 2009
My WF860 is leaking from underneath - do I need to change the door seal?
Posted on Jan 13, 2009
Can I replace the rubber drum seal on my Hotpoint WF860 myself, if so where can I get one?
ebay best place very easy to change if you remove the spring on the seal on the front of the machine you can get to the clip to take of the inside you can take off the lid to get to it from the top thankyou
Jan 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
How do i release band round hotpoint washing machine door seal
The band around the door should have a spring a the bottom, use a needle nose plyers at she spring area and strech the spring to get it off.
The inner band has a bolt head or philip head to loosen it.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Needs a new door seal the seal now on the washing machine is leaking
Hi.
You need Hotpoint part number: 1605550.
if having problems obtaining one please call me on 01733 307019
aardvark repairs
Nov 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Nov 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do I replace the door seal on a Hotpoint WF860
unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
Aug 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Water leaking from front
tear in the door seal, will probably need new seal - had this a few times, apparently usually caused pulling large loads out in a clump pulls and tears at the seal
Oct 24, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
3,303 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
