Cant turn the volume up or down, or change stations, none of the buttons work when pressed. Tried resetting the cd player but it didnt work.
SOURCE: JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
SOURCE: stero stuck on demo mode,
You will find the demo mode in the settings menu. It's options will be on and off and are reset to default each time power is disconnected from the unit.
1st, hold the "SEL" button
2nd, use the left/right arrows to select option "Demo"
3rd, turn the volume knob until "OFF" is displayed
Then, lastly, press the "SEL" key once more.
Here is a link to the pdf document for the instruction manual off the JVC website: http://books.jvcservice.com/Download/717497409/GET0485-001A.pdf
SOURCE: my cd player in demo mode how i change it
Press the Selection button about 3 seconds
When the Demo On mode appears
Turn the VOLUME dial until Demo Off appears
Press the Selection button again to get out of this mode.
Done.
SOURCE: cd player clock settings
Press and hold SEL (select) button on left for 3 seconds
Select CLOCK H on the left or right side of the knob on on the right.
Adjust hour by turning the outside of the select knob
Press SEL to lock hour
Select CLOCK M on the left of right side of the knob on the right
Adjust minute by turning the outside off the SEL knob
Press SEL to lock minutes
Press DISP button
