Question about Dishwashers
I have a hobart dishmachine model# CRS-103
I would like to know were curtains go,and were the correct place for the sprayers go.also if you have a diagram that would be wonderful. please respond. thanks Dave. p.s. could you tell me the year of this machine. Thanks....
THERE SHOULD BE SOME HOOKS AT THE TOP OF THE MACH INSIDE AT BOTH ENDS AND SOMEWHERE IN THE MIDDLE TO SEPERATE THE WASH TANKS AND THE RINSES TANKS, ALSO AT THE ENDS SO THE WATER DOESNT SHOOT OUT ONTO THE FLOOR,THE SPRAYERS COULD EITHER BE THE WASH ARMS OR THE RINSES JETS IF ITS THE ARMS THEY GO IN THE TOP AND THE BOTTOM ONES GO JUST ABOVE THE WATER LINE OR SCRAP TRYS THE BOTH SHOULD LOCK IN SOMEHOW,I IF ITS THE RINSE JETS THE GO IN THE RINSE ARMS WITCH ARE AT THE EXIT END WHERE THE TRAYS COME OUT, THE JETS SHOULD THREAD INTO THE ARMS WICH HAVE PRE DRILELED HOLES FOR THEM.
Posted on Feb 23, 2009
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I need part # and prices
What is the model and ml number of your dishwasher?Its located on the data plate,let me know.
Nov 18, 2009 | Hobart 42 in. AM14C-154 Free-standing...
I have a hobart crs 103 that makes a verry loud noice. It works but it sounds like a 747 taking off. Any qlue
Sounds like a fook,knife, spoon is caught in the pump.I'm a hobart tech and repair them often.Can you tell where the noise is coming from?Let me know.
Nov 17, 2009 | Hobart Dishwashers
Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
Jun 08, 2009 | Dishwashers
Dishmachine lx30h
Did you solve your problem?I'm a hobart tech and can step you through somethings to check.
Apr 12, 2009 | Hobart Dishwashers
Hobart conveyor dishwasher model crs-66 serial#286458 2o8-3ph machine is 38 yrs. old. pilot lite would not stay on. changed thermoule coup. when switched to on everything goes off. this pilot valve is...
I'm a hobart tech,The valve your talking about is the saftey valve.Normally if i serviced your dishwasher i would replace both valves just because how old it is.But in most cases the saftey valve goes bad.The coil on the valve is weak and tends to drop out the voltage.Another thing to check that would cause the same issue is the pilot,especially propane gas.Sometimes you can just clean out the pilot but if it's warped i would replace it.
Mar 27, 2009 | Hobart Dishwashers
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
Dishwashers Logo
168 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
