I have reinstalled my cam several times and when the set up comes up,i can see me,but when i use it to correspond with someone else there is no pic
    Genius:
  • 1,011 Answers
Dear,
tell someone on the other end of messenger or else to send a request from that messenger and u accept that.
u plz check it in this way.
regards,
Posted on Dec 23, 2008
Replaced timing belt need do you start at TDC to
For all timing belts you should start with the crank sprocket pointing at TDC and the cam sprockets pointing at their designated marks.
You should be able to mark the old belt and and put corresponding marks on the cam and crank pulleys, then remove the old belt and transfer the marks to the new belt and install it.
Personally I would buy a manual as this would provide you with a step by step guide to performing the repair.
I am not positive that this is an interference engine, it looks like it is to me. If you are not accurate in your timing you will cause severe engine damage.
Jul 25, 2009 | Isuzu Trooper Cars & Trucks
Timing belt settings
Here is one pic of the timing marks. The cams get lined up with the dots on the back of the timing cover. The one on the cam goes in between the 2 dots.78226419
Jul 23, 2009 | 1994 Mazda 323
Someone please help!!!! I have a 2000 buick
A cam sensor only helps the computer when cranking and should not make it cut off. Most cam sensors do not go bad, but he magnet on the timing gear will deterorate. To fix that the timing cover will have to come off. Replace the crank sensor they get hot and stop working. When they cool down they will work again until it gets hot.
Jul 20, 2009 | Buick LeSabre Cars & Trucks
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Need to know how to set the timing
Cylinder #1 set at TDC, compression stroke. Cam marks level with head, aligned with mark on cover, or if unclear where to mark the cam: SET Cam at point where intake valve has just closed and both valves are shut on cyl. #1, cam gear marks should start to appear more clearly to technician, along with corresponding alignment points. This is ballpark. Remember, on clockwise rotation, after cylinder #1 intake valve(s) are shut, the cam will continue to rotate 90 degrees and come to rest at a position in which both exhaust and intake valves are at their maximum lash point. (the most play) Hopefully if you get this close, you will decipher the marks that exist on your Bavarian machine.
Jan 19, 2009 | 1999 BMW 318 ti
Settings to replace cam belt
There should be marks stamped into the cam and crank gears that need to line up with corresponding marks on the backing plate before you remove the cambelt.
If there are no markings, you need to make your own.
Rotate crank until at TDC (reinstall the crank drivebelt pulley loosely and front cover to do this, then take them off again)
Once at TDC, use correction fluid and mark the crank position twice - once on the crank gear itself and a corresponding mark on the backing plate.
Ditto for the cam gear.
Make sure these marks are aligned when cambelt is replaced, turn engine one full revolution when new cambelt is on to double check marks line up where they should and you're good to go.
Sometimes the cam isn't marked but the crank gear is. In that case line up the crank gear and use the above step to mark the cam gear.
Be precise as the cam gear will most likely move when you take the cambelt off due to tension from the cam on the rockers
Hope this helps :)
Aug 03, 2008 | Daewoo Nubira Cars & Trucks
Sony cyber shot
How do you know it is not your camera's display screen. Download pics to computer to verify. If you do not have a computer, take mem card to a retail photo Kiosk or counter; walmart, drugstores, etc.
If they are still white after reading card, and a pick file exists, then it is probably the Record Mode, pic taking mode, of the camera that is defective, of some setting out of whack.
Try removing the cam battery and reinstall after a 10 sec waiting time. This will reset the camera and put setting back to DEFAULT mfg settings.
Apr 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
VEO STINGRAY PERSONAL WEB-CAM
i have a vista .
the computer is compaq that get vista on it and can not ues
any of my cam 's what so ever
Dec 11, 2007 | Veo Stingray
Video pc cam 600 restarts the pc
Virusss!!!! you need antivirus software, you may also try formatting the pc.
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
