Zanussi FLE1116 Aquacycle beeps but wont start program
Mains power present. Switches on and allows program to be selected, program lights indicated. when start button pressed, nothing happens except single beep. no clicking unless door is open, no sound of motors starting and no flow of water. inlet filter clear and water presure present. manually selecting spin or drain does not work either. No previous problems and machine has functioned normally until now.
  •  Sherman
    Sherman May 11, 2010
    does the washer door lock
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Posted on Aug 13, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL electronics problem
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
Zanussi aquacycle 1200 want open
H? there
This somerimes happens t? my Candy, then I d? the same ?s you.
I also turn to off, wait the desired two minues> turn to empty, most often she does as she is told> turn off, wait the two minutes> turn to spin, turn off> wait the two minutes. This usually works and then I can put on any program. This works for me. Hope you find a solution for you,
kolbrun
Feb 04, 2015 | Zanussi Washing Machines
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Zanussi aquacycle 1200 washing machine
The Timer/ECU is likely failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Washing Machines
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
