Question about Samsung Digimax S800 Digital Camera
My samsung digimax s800 stopped working a couple of days ago. The lens does not retract at all and when i try to switch the camera on, it just beeps three times and then turns off. Can anyone help?
  • joannemagee1 May 16, 2009
    The camera lense is out. Each time I try to turn it on the screen operates for about three seconds, it beeps three times and then turns off. The menu is inoperable during the three second period
Ok I had this happen to me a lot when I was using normal batteries...I have since switched to lithium and have not had a problem since.
Posted on Jul 05, 2009
  • 75 Answers
Try to replace the battery with rechargeable ones.
And if that doesnt work, call 1-800-SAMSUNG and have your camera sent for service.
Posted on Jan 19, 2009
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
Samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Samsung S800
Lens mechanism can be stuck. Try gently to drag or straighten it.
Feb 13, 2008 | Samsung Digimax S800 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
410 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
