Question about Sony VAIO VGN-FS660/W Notebook
Overheating, need to clean fan cooler
Hi, any tips on how to access the inside of this laptop? I've tried , but it's not easily accessible.
  • Martin Stephen Dec 24, 2008
    Thanks Boogerhead01! This really helped..it was not a perfect match but close enough to make the difference. I was able to get the laptop opened up and clean out the fan cooler.
    It definitely is running cooler now. Thanks!
  • cprfield May 03, 2009
    Shut down on overheat after through cleaning. The sytem is running at 1/2 speed to avoid the shut down. When the machine boots the fan comes on for a moment at full speed, then backs down to the quieter speed never to be heard from again.
    How can I get the fan to kick in when required or if need be run at full speed. I have tried Speed Fan but it does not find any fan to control.
    Any suggestions, Thanks Christopher
    Novelist:
  • 159 Answers
There are disassembly guides for your computer's cousins that may be in the ballpark enough:
http://repair4laptop.org/disassembly_sony.html
This -might- be the closest match; I'm not quite sure:
http://oddsandends.canalblog.com/archives/2008/01/29/7745892.html
I'm assuming you've tried to use canned air on the intake and exhaust ports?
Posted on Dec 23, 2008
How to I stop my HP laptop from overheating
Office Depot sell a "laptop fan" for your lap or desk station, this will raise the unit up off the surface and allow air to circulate more.
Jan 27, 2013 | Computers & Internet
Cooling fans are too loud
Hi.
Sounds like the laptop just needs a right good clean out of dust. Get a can of compressed air and clean the air vents and the fan grill if you have access to it, that should quieten the laptop down. Dust is a common cause of noisy fans.
Regards.
Jan 02, 2013 | Computers & Internet
How do I access the fan on an HP Pavilion DV3 Laptop? I've taken it apart with the online guide available but that failed to access the cooling fan. Laptop is overheating and it's clearly the...
Honestly, try harder. If you've taken the thing apart, you're more than half way there. You probably just need to unscrew more stuff and pry more parts out.
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
My laptop keeps overheating. I have tried disabling a lot startup programs and deleting files. Can you please help me with this?
You didn't mention what make and model laptop you have but here is a general solution. Laptop overheating issues almost always involve fan blockage, or a bad (non-functional) fan. Some are easier to access than others. Look at your laptop and see if you have access from the bottom. You could possibly even access by removing the keyboard. IF you can access the fan you should clean out any lint or dust that is causing blockage of airflow (some dis-assembly may be required). KEEP IN MIND that if you remove the fan heatsink assembly you will need to re-apply thermal paste or compound to the area between the CPU and heatsink.
My guess is you will find that you have a strip of lint blocking the airflow between the exhaust of the fan and the heatsink fins.
Apr 28, 2011 | Computers & Internet
Its overheating and shutting down after maybe 15-20 minutes
Almost certainly a clogged cooling fan , vents or build up of dust on the cooling fins. You will need to gain access to the CPU fan and remove the heatsink assembly, blow all dust out of the cooler matrix, clean the fan blades and the cooling vents. Clean off any thermal paste on the cpu and regrease with new paste, refit and reasemble.
You CAN cut corners by cleaning it "in situ" but a thorough cleaning is advised.
Eventually if not cleaned, teh graphics chip will fail with overheating
Jan 29, 2011 | Computers & Internet
HP nc 6220 overheating? problem.
It sounds like you do have an overheating problem. When the laptop is running, peek inside the vent on the side or bottom of the laptop and determine if the fan is running. If it is running slow or completely stoped, that is your issue and it should be replaced by a local repair shop.
If the fan seems to be running fine, you may be able to deal with the problem and extend the life of the laptop a little by buying a laptop "cooling pad" which will have cooling fans of its own.
May 30, 2010 | HP Compaq nc6220 Notebook
Toshiba laptop will keep shuting off
It is because of the laptop overheating problem. This is a very common problem with and could be easily fixed if you clean the heat sink. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
(If this tips helpful please rate this solution)
Feb 26, 2010 | Toshiba Satellite A215-S7422 Notebook
It keeps overheating and then shuts down
Try vacuuming the airvents and see what happens.
Also make sure you are not blobking the airvents in anyway.
Another way would be to open the laptop and reseat the CPU heatsink but this is only for advanced users.
Sep 21, 2009 | Toshiba Satellite Pro L300 Notebook
Overheating problem, with fan stopping randomly
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Feb 19, 2008 | Acer Aspire 3000 Notebook
How to open laptop?
There is usually a screw or two inside the memory access panel, hard drive access panel and/or under the battery. Make sure you have checked/removed all of these. Does it appear to be loose for the most part? Even once the screws are removed there may be interlocking clips along the edges the hold the housing together. you can test one spot with a small flat screwdriver to see if it "pops" apart. Here is a website to find service manuals/info as well: http://www.eserviceinfo.com Good Luck
Jun 25, 2007 | Acer TravelMate 8210-6597 Notebook
Sony VAIO VGN-FS660/W Notebook Logo
333 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
