Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Dishwasher won't fill - inlet/outlet light comkes on
Got a miele dishwasherhave had similr problems to this in the past with blocked outlet pipe. This time drians well appears it is not filling at all, although can't find any reason why not?
  • Anonymous Apr 01, 2014
    I need an outlet pipe to be about 4.5metres
    President:
  • 1,462 Answers
Check no water in the base either by taking front bottom panel off or tilting back. if water runs out, means you have a leak. could also be inlet valve open circuit
Posted on Apr 10, 2007
WATER IS STREAMING OUT OF THE BOTTOM OF MY HAIER AC HPRD12XC5 VERY LITTLE COMES OUT OF THE DRIAN . I OPENED THE DRAIN AND A COUPLE OF OUNCES CAME OUT. MY CONCERN IS ABOUT THE WATER RUNNING ,
It is quite likely that there is a collection tray or tank for condensation inside the machine. The outlet pipe is quite likely blocked. Disconnect it from the mains (just in case) and gently push a piece of wire or stiff plastic rod (strimmer cord ?) up the pipe.
Jul 18, 2017 | Haier Heating & Cooling
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Hello. My dishwasher (Miele G 579 SC) does not fill water enough. When filling is done I must fill manually with a bucket to get water to a sufficient level. What might be the problem? Kind regards...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 05, 2011 | Miele Dishwashers
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
My miele dishwasher model no G643V1 is not cleaning properly. Inlet/Outlet, Salt or Rinse aid lights not red. Contents all have gritty substance at bottom. Please help!
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 08, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Doesn't fully drain between and at end of cycle i believe th e drain is partly plugged how do you clean drian.
Remove the bottom strainers plates and make sure that there is nothing obstructing the outlet pipe and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 23, 2011 | Dishwashers
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
How do i change a water pump in a 97 grand am with a 2.4 litre engine
2.4L Engine
See Figure 3
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Disconnect the oxygen sensor wiring.
  4. Remove the upper exhaust manifold heat shield.
  5. Raise and safely support the front end of the vehicle securely on jackstands.
  6. Remove the exhaust manifold brace bolt.
  7. Unbolt and remove the lower exhaust manifold heat shield.
  8. Break loose the manifold-to-exhaust pipe spring loaded nuts.
  9. Unbolt the radiator outlet pipe assembly from the water pump cover.
  10. Disconnect the exhaust pipe from the manifold.
  11. Pull down and back on the exhaust pipe to disengage it from the exhaust manifold bolts.
Do not rotate the flex coupling more than 4°. this could damage the component.
  1. Separate the radiator outlet pipe from the oil pan and transaxle.
    1. On manual transaxle, remove the exhaust manifold brace.
  2. Next, leave the lower radiator hose attached and pull down on the outlet pipe to detach it from the water pump. Allow the outlet pipe to hang.
  3. Lower the vehicle.
  4. Remove the exhaust manifold-to-cylinder head nuts.
  5. Extract the manifold, seals and gaskets.
  6. Remove the timing chain cover. Refer to the procedure later on in this section.
  7. Remove the timing chain tensioner. Refer to Timing Chain removal later in this section.
  8. Unbolt the water pump from the cylinder block.
  9. Extract the pump assembly-to-timing chain housing nuts.
  10. Remove the water pump and cover assembly.
  11. Separate the pump from the cover.
  12. Clean all mating surfaces of gaskets and sealant materials.
To install:
Prior to installing the water pump, read the entire procedure. Pay special attention to the tightening sequence to avoid component damage and ensure a proper seal.
  1. Attach the water pump to the cover and hand-tighten the components.
  2. Lubricate the splines of the water pump drive with chassis grease or equivalent, then install the pump and cover assembly. Hand tighten the cover-to-block bolts.
  3. Install the pump-to-chain housing nuts and hand-tighten.
  4. Lubricate the O-ring on the radiator outlet pipe with an anti-freeze solution and slide the pipe into the water pump cover, install and hand-tighten the bolts.
  5. With the specified gaps, tighten in sequence as follows:
    1. Pump assembly-to-chain housing nuts
    2. Pump cover-to-pump assembly
    3. Cover-to-block, bottom bolt first
    4. Radiator outlet pipe assembly-to-cover
  6. Install the exhaust manifold using new gaskets.
  7. Install the manifold-to-cylinder head nuts, follow the tightening sequence and tighten to specifications.
  8. Raise and support the front of the vehicle.
  9. Index the exhaust manifold-to-exhaust pipe flange bolts.
    1. Turn bolt bolts in evenly to avoid cocking the exhaust pipe and binding the bolts. Turn the bolts in until they are fully seated.
  10. Install and secure the radiator outlet pipe to the transaxle and oil pan.
On manual transaxles, install the exhaust manifold brace.
  1. Install the timing chain tensioner and chain cover.
  2. Attach the lower heat shield.
  4. Attach the exhaust manifold brace. Tighten the manifold-to-exhaust pipe nuts to specification.
  5. Attach and secure the upper heat shield.
  6. Connect the oxygen sensor wiring.
  7. Fill the radiator with coolant water mixture until it reaches the heater hose coolant outlet, then install the hose and continue to fill. This will assist with the complete cylinder block fill.
  8. Connect the negative battery cable.
  9. Start the engine and top off the cooling system and check for leaks.
Dec 28, 2009 | 1997 Pontiac Grand Am
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
1,146 people viewed this question
Top Miele Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
