Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Can't find manual or model# amana 95% eff. furnace.
Help. My house is cold. Furnace lit..not producing enough heat???
  • 306 Answers
Does it shut off real early in the cycle?
Posted on Dec 23, 2008
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
Pilot on my gas furnace won't stay lit
Try cleaning the thermocouple tip if you can see ashes or any buildup on it. If you know the wind isn't blowing it out (had mine blow out from high winds before) then I would change the thermocouple before anything else.
Dec 09, 2013 | Heating & Cooling
Amana Distinctions 5 ton premium R410A system inducer draft motor short cycling and fan does not run
Amana distinctions furnace is the top quality furnace and I would you recommend to get professional technician help for that. You may call in Toronto at 905 201-1293, Clean Air Heat is there to help you out.
Jan 01, 2013 | Amana Distinctions 95% Gas Furnace...
I have a Trane 90XL installed in 2001which has been running great for 10 years. Now in very cold temperatures this week there is water seeping from the base of the unit. Water is slightly yellow/green in...
Make sure all of the condensate lines are open. The Hose and traps from the furnace. With the cold weather the Furnace is running alot more and Condensing more water from the Flue Gases.
The Furnace can produce up to 5 Gals of water in an 8 hour period. If the drains are all open then you better get a professional to check out the furnace you could have a cracked secondary Heat exchanger which could be leaking carbon monxide into the house. Do you have a CO2 Detector in the house??
Jan 21, 2011 | Heating & Cooling
My furnace comes on and heates the house for about
There is a limit switch that is likely opening. Be sure your filters are clean and all registers and grilles are open and not obstructed. If the problem continues, you may have a dirty indoor coil or undersized duct work. Some models have a window where you can observe the LED lights. If when the furnace shuts down you see any blinking, you need to count the flashes and we can figure out what the problem is from there.
May 13, 2010 | Ruud UBHC Air Conditioner
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Mar 22, 2010 | Ruud UBHC Air Conditioner
My heat won't blow through the vents. The furnace ignites itself but it cuts off after a minute. I've sanded the flame sensor but it still won't work. What can I do now? I just want heat in this blizzard!
If the ignitor glows and the burners lite and then shut off, the flame sensor was the best place you could
start at.
If this is a reg gas furnace or a High EFF. furnace make sure your gas meter is not covered up with
snow.
Turn your thermostat all the way up, if the furnace
does this 3 times in a row-then it should go into
a lock-out mode. Has it done that?
On reg. gas furnace make sure your chimney is
not obstructed where it connects to the furnace.
If it is a High EFF furnace make sure the pvc exhaust
vent is actually venting. It should also have a pvc intake air vent make sure that is not clogged.
If it is a high eff furnace, turn unit off and remove
the door that covers the ignitor and burners. This is
usually a interior door with a sight glass in it. Turn
furnace on, if it lights and stays operating, then you have a problem with the intake vent
Feb 11, 2010 | Heating & Cooling
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
How do I relight Pilot for a Model # Carrier 58GP100-3 Furnace?
as the unit is very old there is no specific manual available for it to guide you but i will give u some link for extra help.
Nov 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
179 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
