Question about Honeywell Heating & Cooling
My honeywell electronic air cleaner, does not work no power on the high voltage card, l need a schematic for the MPLS MN 55422 card so l can fix it. Help john
  • j_swilklo Dec 23, 2008
    My furnace honeywell electronic air cleaner does not work. The board mpls mn 55422 has no high voltage. Power to the card is ok. I need a schematic diagram for this card so l can fix it. Can you provide one or not.
    It is not a air conditioner l have a problem with it is the Honeywell electronic air cleaner. I need a schematic diagram of the mn 55422 board so l can fix it. So yes you have the diagram or no you do not?????????????????
  • 19,396 Answers
The service manual is not available for free download, and schematics are also not available.
You can get the servive manual by callug at
1-800-955-7075 ,here is the website
Honeywell Filters and Parts for your Air Cleaner.
They also sell the replacement board.
Posted on Dec 23, 2008
  • 15,935 Answers
MPLS MN 55422 is not the proper number of the board. Maybe this is the confusion.
That board was manufactured in minneapolis, MN zip 55422
Please resubmit with proper ID
    President:
  • 2,110 Answers
    Sergeant:
    Novelist:
  • 327 Answers
  • 700 Answers
Is there a test button on the air cleaner' Also there's a interlock that has to be made before the unit will work. usually the installers hook the high voltage up to the furnace power. The inter lock is called a current sensing relay and it is hooked up to the common of the blower in the furnace. Hope that this helps and thank for using FixYa!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sorry no schematics. Would you consider board replacement? If yes, might this help?
Good luck and Thank you for using FixYa. Happy Holidays.
  • 837 Answers
What is the model of your AC unit?
    Genius:
  • 1,011 Answers
Sir,
click this link for more information
thanks
g.luck
Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Can't get the thermostat to turn on. The batteries are good, but the thermostat won't turn on when I slide the thing from off to the heat. I have a Honeywell MPLS, MN. thermostat (this code was found at...
Try with following link:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating b>
Dec 09, 2010 | Heating & Cooling
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Apr 07, 2009 | Water Heaters
I want to try replacing the electrolytic capacitors Honeywell Part 136912 in my Honeywell F50A Electronic Air Cleaner with locally available parts. What are the capacitance and voltage ratings?
In my F50A1066 the capacitors are .022 uF (microfarad) with a 6000V rating. One is blown on my unit and I found a close replacement on Ebay (.02uF with a 16000V rating) for $5.00.
Oct 21, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
272 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Paul
Paul
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
