Question about IBM ThinkPad 600E 2645 Notebook
Installation of XP hung up and will not complete - system down
Hi!
Have and IBM Thinkpad running XP. Numerous problems with blue screens so off loaded personal file and went into IBM consol and went through restore system to factory settings. Looked good except system would not recognize USB ports through My computer. Attempted to troubleshoot and reinstall drivers no luck.
Decided to reinstall XP from Microsoft disk. Kept the IBM partitioning but installed the latest XP on another. Going through the windows installation screen got to windows install and now stuck halfway through. Error message regarding installation of Explorer intallation.
  • 1 more comment
  • john_lanning Dec 23, 2008
    Since the Windows Installation screen was static for nearly 2 hours with no hard drive activity (but the Windows information screen still displayed an array of windows XP features) I shut the system down. Now when I reboot it always goes back to where the windows installation screen left off...
    When I eject the CD to stop I get the following message.
    System Setup Log - (C:\WINDOWS\setuperr.log)
    "Fatal Error:
    One of the components windows needs to continue setup could not be installed.
    The operation was canceled by the user."
  • john_lanning Dec 24, 2008
    Thanks for the information - nice to know there may be a couple options here. How simple .... will check the cd.
    Out of town for the holidays but will post the outcome once I return.
    Best to you all!
    JmL
  • Boogerhead01 May 11, 2010
    What's the error message?
    Novelist:
  • 159 Answers
What mybox258 said -- looks like a bad CD, but you can try a workaround. Please read my whole post before diving in, because you've got several options and things that might or might not work, and it's up to you to decide how to squander your time. =)
Microsoft has some instructions here:
http://support.microsoft.com/default.aspx?scid=kb;en-us;812247
You can get a replacement CD from Microsoft .. I think they used to charge $10. BUT before you do that, you can
A) wipe off the CD
B) download a Windows bootdisk (http://www.bootdisk.com/bootdisk.htm has them)
C) follow the third set of directions in that Microsoft link I pasted above.
EXCEPT: All this is based on the premise that, well, your computer's hard drive isn't formatted to NTFS instead of Fat32, because Win 98 and ME won't read 'em. It would've been helpful if Microsoft told you that, instead of telling you to use those specifically.
So if you scroll down farther in that Bootdisk.com page, you see some links to NTFS boot disks; get those:
http://www.bootdisk.com/ntfs.htm
Alternately: Now, you may be able to take that clean your original XP CD, clean it, and see if you can copy it on another computer that may have a better drive. You'll still need your key, of course. And then immediately shred the replacement CD -- I don't know for sure the legality of this, even for private use -- I suspect it's a gray area. If you don't have CD copying utility, the free ImgBurn can do it for you:
http://www.imgburn.com
There's no direct copy function, but you can make an image of your existing CD; then burn the image to a new CD.
Please write back if none of this gets you anywhere.
Posted on Dec 24, 2008
  • 74 Answers
Well it sounds like you have a dirty cd or a bad cd.
Turn the cd upside down and look at it usually when you get the hang it means that the eye stopped moving from either somthing on the cd so clean the cd then try.
If it still doesn't work then see if there is a deep scratch on the cd.
But my bet would be is the cd needs to be cleaned
I have a ibm thinkpad t43 model laptop. the problem is after format the hard disk i install the audio driver (download from the web) but it can't work but earlier that driver work
I am not sure which OS you have installed, any how if you have installed XP on your notebook then us the provided URL to download and install the audio drivers:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ya210ww.exe
Installation Instructions
This driver can be installed with the Software Installer, or
by following the instcructions in the next section.
In both cases, please confirm that the driver is correctly installed,
by determining the installed driver version as described below.
Clean installation:
1. Start Windows and log on with the user ID authorized as
an administrator for Windows 2000/XP.
2. Extract this package onto the hard drive.
3. Click Start, then click Run.
4. Type C:\DRIVERS\WIN\AUDIO\SETUP.EXE in the Open box and click OK.
5. Follow the instructions on the screen.
6. Click Finish and Reboot the system when prompted in order to
complete the installation.
Upgrading or reinstall:
Note: Remove any previously installed driver using the uninstall step
5. If the dialog box appears, select Reinstall or Update and then
click Next.
6. Click Finish to reboot the system and complete the installation.
Unattended installation (Windows 2000/XP):
Note: This is for system administrators' use only.
In the step 4. of the Clean Installation procedure type
C:\DRIVERS\WIN\AUDIO\SETUP.EXE -S -SMS in the Open box and click OK.
Jun 05, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
Need to upgrade from windows 98 to windows xp on ibm 760e thinkpad
Before you begin, be sure to go to Lenova Website and download the appropriate XP software & drivers and burn them to a CD or flash drive. You will need them after the install is completed. After that is completed, you are ready to install. Insert the XP Install disk and choose INSTALL XP and on the next screens drop down menu, choose UPGRADE. Follow the instructions. After it is completed, use the CD or Flash Drive to install the proper system software & drivers.. GREAT LUCK!! Please rate me, k? Thank You Lucky4lynn2
Mar 06, 2010 | IBM ThinkPad 760E (9546U4A) PC Notebook
IBM thinkpad wont work
Try to get hold of a bootable xp pro disk and boot from it, when finished loading the initial drivers and files onto the system gointo the 'R' option recovery console, this is a command line recovery, once there type chkdsk c:/f and press enter let it run its coarse and then restart pc.
Jan 21, 2010 | IBM ThinkPad R31 2656 Notebook
Ibm thinkpad A31 Windows unable to start normally. Message on blue screen indicating "unmountable_boot_volume". Also got "Kernal_data_inpage_error" message. Does this indicate hard drive failure??
No, this is a known error within Windows. Read more information on it here: http://support.microsoft.com/kb/555302
But, if you are like me and don't like to read, just put your windows XP installation CD into the CD-ROM, boot up from the CD-ROM, DO NOT reinstall the operating system...just repair the installation and run "chkdsk /r".
Once that is done, restart the machine and it should boot up fine.
Jan 08, 2010 | IBM ThinkPad A31 Notebook
I can't load any OS on an IBM Thinkpad
Since both operating systems are failing to install, I would suspect that there is a problem with the installation of the harddisk (cable not securely connected) or the new harddisk is faulty.
Dec 08, 2009 | IBM Thinkpad I1400 I1500 2611
Blue screen on Thinkpad R51e & cannot be shutdown
what operating system are you using and please be more descriptive regarding "blue screen" is it the notorious microsoft "Blue Screen of Death"? or? when this occurs is the system totally locked? or can you hit ctrl alt del and get the task manager? can you boot into safe mode? if you're using xp and can get to safe mode.. have you attempted to restore to an earlier restore point prior to this issue? if yes and you haven't restore back to before issue occured.
May 20, 2009 | IBM ThinkPad R51 Notebook
IBM 2647 -41U automatic shut down
How old is your computer??? is it getting overheated?..what operating system did it have before xp? does it give you any messages before shutting down?
let me know
Apr 10, 2009 | IBM ThinkPad T20 2647 Notebook
Cannot reboot IBM thinkpad t-21
There must be some driver you have installed recently. Try booting in safe mode and restore your system to an earlier date.
Oct 16, 2008 | IBM ThinkPad T21 Notebook
T23 Startup problems
if you tried to install the belkin usb wireless adapter, what might be happening is that the device is searching for the driver and stopping your desktop from loading, so remove the usb dongle and do a system restore to the day before your problem if necassary. Make sure that you install the belkin software first then connect the adapter whe prompted as sometimes the driver can be a bit tricky to install.
Sep 02, 2007 | IBM ThinkPad T23 2647 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
134 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
