Sony connectivity Hi Thank you for responding. The Bravia model number is KDL 37P 3020, the DVD is RDR HXD 890 (brand new out of the box) and the Sky box is a srandards Pace model. I only have Sky input (ie no standard aerial). Any guidance grarefully received! Regards Brian
  • bitaylor Dec 24, 2008
    Thanks for that welcomejee, but where do I add my Sky box?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Let me have info for both units and will reply you shortly.
    Thank you.
  • 10,594 Answers
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Posted on Dec 23, 2008
    Shahid Electronics Dec 24, 2008
    Sky box will be connected in component or composite video in of TV
Can not record or playback on sony rdr hxd 890 Help please from a repairer. rdr hxd 890
http://www.sony.co.uk/support/en/product/RDR-HXD890/downloads/FW_DVDR_124 Make sure the ribbon cable going to the laser head from the main board is seated correctly at both ends. Use a scope to verify signals present at the input to the laser. If not then find where it stops on the main board. If it is present then replace the laser mechanism.
Jun 24, 2016 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
SONY DVD RECORDER PROBLEMS
if it is only some programs, verify that your recording times are not overlapping and you are setting the timer for the correct times
Mar 17, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
I have recorded a film onto the Sony RDR HXD 860 HDD and then I burned it onto a DVD. I took the DVD and inserted it into my PC and would like to know how to convert that into a DivX
Hi
You need a DVD convertor program that converts to Divx. There is a range of freeware available on the net.
Check out "freeware.com" or in the search box "freeware search"
Regards
Phillip
Oct 16, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Cannot access the "guide" facility "t
i had a similar problem with the 870 model. i reloaded all the channels using the "initial setup" menu and everything was back to normal. charles
Apr 25, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I lost DVD Sony RDR-HXD 870 insructions. Could you possibly send it to me electronically?
Hi here is a link to Sony manuals downloads
http://support.sony-europe.com/manuals/index.aspx?site=odw_en_GB#m=RDR-HX870
It seems to be only available in Slovenian (probably only produced for that region?)
On right side of page select from drop down box 'home video', second drop down select 'dvd recorder' then in third drop down you should see your model number RDR-HX870 (without D). Download is 3.16mb.
Hope that helps and you can read Slovenian?
Apr 23, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Cannot remove caption
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Nov 25, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony DVD RDR-HX650 - set up
Sony UK has info how to hook up this unit. Please check there.
Sep 05, 2008 | Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
