Question about Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive
I want usb hard drive - Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive
  • 69 Answers
  • Peter Sturniolo
    Peter Sturniolo Dec 24, 2008
    This is not a store, nor a classifieds site. You want a USB Hard Drive? Go buy one. If you need help with getting one to, describe an actual problem.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Transfer stuff from a working and put it on another hard drive
The easiest way is to connect your hard drive to an USB hard drive adapter or USB hard drive dock, then plug this USB adapter ot dock into the USB port of your computer. The computer will see this as an external storage device, you can then open the various folders and copy the folders or files to the computer,
If you want to copy these folders or files to another hard disk then connect the other hard drive to the USB hard drive adapter or USB hard drive dock and plug it into your computer and copy the folders or files from your computer to the external hard drive.
Mar 28, 2013 | Maxtor Hard Drive
Bottom part of the hard drive has been lost, the part where the power and the usb plug into, is there anywhere i can buy that part??
I think you are referring to an external USB hard drive case.
I suggest you remove the hard drive from this USB hard drive case and install the hard drive in a new USB hard drive case.
Feb 27, 2013 | Computers & Internet
Please help me with this
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
Seen as movable
If you change the Boot Device startup order with the USB port as the first boot device then you can boot up with an USB hard drive or USB Flash device.
If your hard drive is the first boot device then your USB hard drive will not boot up first.
Aug 01, 2012 | Transcend 750 GB 2.5-Inch USB 3.0 Super...
OKI (70050501) 20 GB Hard Drive
To back up the data from this hard drive, connect this hard drive to an USB hard drive adapter, then plug this USB adapter with the hard drive into the USB port of a working computer. The computer will see this hard drive as an external mass storgae device. You can then open the folders and files on this hard drive and copy your data to this computer or to an USB memory stick.
Jun 04, 2012 | OKI (70050501) 20 GB Hard Drive
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
