Question about HP Pavilion dv9000z Notebook
Pavillion hp 6000 power button won't turn on laptop
The light comes on in the adapter on the right side by the cdrom drive but when I press on off button nothing happens.
  • 2 more comments
  • hstarkman Dec 23, 2008
    No power, no nothing happens when I hit the on button. Period.
  • Anonymous Jan 03, 2009
    Sounds like the problem I have, although when I press the power button all the LEDs flash for about one second, then go out. Same thing if I press and hold the power button - LEDs go out after about a second.
    My pc is a HP Pavilion dv6000
  • kolya1971 Apr 27, 2009
  • Anonymous May 08, 2009
    impossible if you can't turn the thing on, Boogerhead!
    Scholar:
  • 180 Answers
From experience I can tell you if the unit is an AMD processor unit or an intel unit you have a nvidia chipset failure. Only rectification is a replacement m/board. Hp has a limited service enhancement entitlement program - check to see if your units product number is listed on this site - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
if so ring Hp support and claim your repair entitlement ASAP
Glenn
Posted on May 09, 2009
    Novelist:
  • 159 Answers
Take a look at Start; Control Panels: Power Options. You can configure the function of the button there; it may have gotten goofed up somehow.
Posted on Dec 23, 2008
HP Pavillion DV6 won't turn on
if you left it in a dusty place try clearing the dust from the fan outlet to see if that helps
Jan 07, 2013 | HP Pavillion DV6985SE Notebook
Pc won't come on when i press the power on button
With HP there are a few possible answers that I will give you that you could try. One is it could be the switch, I have had a few with this problem. Two is it could be a fault on the mobo (video overheated and come unsoldered) this was a favorite problem with the Pavillion 6000 series, and I have had more than I wanted of these in to sort out. Sorry I cant be more helpfull but you havent given much info on your problem, was it working ok before? has it given you other problems before this happened? etc.
May 06, 2012 | HP Pavilion dv9000z Notebook
Hi, I have a inspiron 6000. 6 years old but works like a charm. Only problem now is the adapter won't charge [not an adapter issue as it works on other dell laptops]. And after the battery has...
Remove the battery and replace it, test. If this does not work, attempt to power on with the AC adapter plugged in and no battery in the system. If this works, you have a bad battery. If this does not work, watch the light on the ac adapter. If the green light goes out when you press the power button, something more is wrong with the system. Further information is desired. When you press the power button, do any lights on the system light up? Do the fans in the computer turn on? Does it make ANY noise? Finally, if available, it is desirable to try a different and known functional AC adapter.
Sep 17, 2011 | Dell Inspiron 6000 Notebook
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Won't come on, tried taking out battery and that
take the cd drive out and look to see if it has grounding out marks on the back and look inside the bay
May 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dv 6000, won't power up
call hp [800-474-6836] if you are in warranty..... because there are certain steps to be followed by hp and they will fix it for free
Mar 14, 2009 | HP Pavilion dv6000z Notebook
HP pavillion ze4420us
press the reset button on the BOTTOM of the computer
Nov 19, 2007 | HP Pavilion ze4420us Notebook
HP Pavilion dv9000z Notebook Logo
625 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
