Back to:
Tags:
Proton MM2701VT 27
What's the difference between LCD Flat-Panel and... (by 3 users)
By Duke - usenet poster
What's the difference between LCD Flat-Panel and Plasma Flat-Panel?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 29, 2008
Ok so if anyone can help... I still don't know which to get the plasma or lcd? I want a 42 inch for an average sized living room, there is not too much light, but a double window on one side of the room, and what brand would you all suggest? Thanks
Comment by Guest, posted on Dec 06, 2007
The area for my new HD tv is a faminly room. The TV will go on a wall next to a sliding glass door, therefore there will be a lot of light. I've heard that LCD is the way to go in this type of room. Did i hear correctly?
many thanks,
ken
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Peter1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In all the ways that really matter, there isn't that much of a difference between the two. Both types of Flat-Panel TVs are thin enough to be placed virtually anywhere, and produce a picture that is startlingly clear, sharp, and bright. The only difference that really matters is the screen size. The majority of LCD TVs have a screen that measures 30" and smaller. TVs with a screen of 32" and larger are typically the domain of the Plasmas.
Technically, LCD and Plasma TVs are entirely different approaches to the same result, because they create images using completely different technologies.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on What's the difference between LCD Flat-Panel and Plasma Flat-Panel?:
I don't want to Accept this solution
Solution #2
posted on Jun 28, 2008
Not Rated (0)
ask1_austin
Rating: 0%, 0 votes
Check the power consumption. LCD TV's, size for size, use about 1/3 the power of Plasma sets. Nowadays you will notice the difference in the electric bill if you watch much TV. And LCD TV's are available in 52" and larger.
Steve in Austin
Thank You!
Solution #3
posted on Dec 23, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Plasma screens have a very shiny reflective screen.
LCD's have a matte finish screen which is better in a brighter room, with less reflection.
Thank You!
Solution #4
posted on Apr 16, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
plasma does not look as good as lcd due to plasma has a glass screen and reflects horribly lcd does not have this major draw back
Thank You!
Can you Help with these Standard Televisions problems?
Proton MM2701VT 27" TV
On occasion I will be unable to turn off my JVC Model...
i have a picture and all functions work but the sound is...
My tv turn off by it self. The sound will still go one for...
model #HLN5065WX/XAA My tv keeps pausing while it's...
This TV is Model MS3252S431 and gets error codes 11.0 and...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
