Question about EliteGroup PM800M2 Motherboard
EliteGroup PM800M2 bios no reconce sata de 160 GB
Poseo una motherboard EliteGroup PM800-M2. Le coloque un HardDisk Sata Hitachi de 160 GB y la Bios no la reconoce. la MOBO tiene activado el OnchipSata en modo IDE y sin embargo no la reconoce. Cual sería la Solución?
I have an Elitegroup PM800-M2 motherboard. We place a HardDisk Hitachi 160GB Sata and Bios does not recognize. MOBO has enabled the OnchipSata IDE mode and not yet recognized. What is the solution?
  • 6 more comments
  • guyglesias Dec 23, 2008
    Has installed an LG DVD-RW IDE, and the order is: CDROM HARDISK, Floppy
    I found that the driver VIA VT8237
    is not compatible with SATAII jumpenado but if it works but the disc SATAI problems????????
    the bios of the card does not recognize the SATA 160 GB
    The Motherborad not recognized Hardisk Hitachi SATA 160 GB. andalusia
    not recognized by the BIOS, I can not install Windows XP. Supposedly
    the VT8237 chipset does not work with SATAII.
    Find This:
    The drive is simply NOT RECOGNISED by the VT8237 controller when
    plugged into the mobo! BIOS is the most current available, Sept 2004.
    It appears VIA know all about this and haven't offered any resolution
    save buy a SATAII board or another board with a different controller or
    a board with their *fixed* 8237R Plus controller. What compounds the
    problem is even with the drive jumpered to force it down to 1.5Gb, as
    the Auto Negotiation seems FUBAR in the VT8237, it still isn't
    recognised! So it was a wasted afternoon and an exercise in futility!
    So just a lesson to those thinking of buying a SATAII 3Gb drive and
    thinking it will run on any SATA controller, BEWARE of mobo's with the
    VIA VT8237 SATA controller as it appears incompatible with SATAII 3Gb
    drives, at least with a Maxtor model 7V300F0 it is!!
    Doing more googling, it appears VIA VT8237R, VT6240 and VT6241L SATA
    Controllers are suspect too with 3Gb SATA drives, nice to know init!
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Could you clarify your last statement please
  • Jay Glendenning
    Are you trying to install a fresh copy of windows on this drive?
  • Jay Glendenning
    Is there an IDE drive connected also?
    Have you checked your boot order in the BIOS?
mastericpr08
  • 571 Answers
SOURCE: mi problema es cuando prendo mi pc no arranca
Verifique la tarjeta de video or replace the memory
Posted on Jan 07, 2011
djnick989
  • 1067 Answers
SOURCE: computer won't recognize sata dvd burner
is jumpers on corect cant u just use ide cable instaed u said your going from ide to sata cable ?
Posted on Jan 19, 2008
SOURCE: PM800-M2 No sound
If you don't have the manual for the PM800-M2 dowload it from the ECS website.
There is a front panel audio header at the back of the motherboard just in front of the onboard sound rear connector.
If the front panel out put isn't being used the front panel audio connector requires 2 jumpers to be on the header in the correct locations.
Posted on Jan 20, 2008
map9966
  • 2351 Answers
SOURCE: EliteGroup 661GX-M2 Motherboard
Hi gohanz777, just click the link below for you're EliteGroup 661GX-M Motherboard. Everything you need is listed here.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=505&DetailName=New&DetailDesc=661GX-M%20%20(V1.0B)&CategoryID=1&MenuID=82&LanID=0
Including display driver.
Luck!
Mike
How to place a vote for you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 12, 2008
map9966
  • 2351 Answers
SOURCE: System won?t recognize SATA drive
No, the size does not matter. When you state the motherboard does not see the SATA drive are you saying the bios does not list the SATA drive? You're 750GB drive is most likely SATA 2.0 / 3.00BG transfer rate.
The P4M800-M7 does support SATA but it does not support SATA 2.0. So what you need to do to get the drive to function at a lower speed. Set to run Ultra 100/133MHz. You'll need help to do this. Try this software for Seagate. It might work for Seagate.
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=126&orderNum=2
I haven't the time to research Seagates site for simular software.
However you can look through Seagate. Again you want to lower the SATA drive speed to Ultra. The bios will than see the SATA & so will windows.
http://www.seagate.com/www/en-us/support/downloads/seatools
Good Luck!
Mike
Posted on Jul 12, 2008
Hitachi Deskstar - modelo HDP725050GLA360 Sata... tengo este modelo de disco lo tengo en ungabinete externo de disco se cayo y ya no lo,lee tampo en una comutadora como puedo salvarlo
Hola que tal, tengo malas noticias, cuando un disco duro se cae lo mas probable es que se dañe, lamentablemente no hay forma de reparar el disco pero sí de extraer la información que está grabada en él, cuesta muchisimo dinero extraer la informacion ya que requiere de equipos y personal calificado para la recuperación, si la información es muy importante y si puedes pagar aproximadamente 600$ por la recuperación el camino a seguir es buscar una empresa de recuperación de datos en tu país.
Lástima darte estas malas noticias...
May 30, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
How do i get the mob and bios to recognize a sata drive
make sure that it is plugged into sata 0 or 1 and then go into the bios and make sure the SATA drives are enabled
Dec 23, 2010 | EliteGroup PM800M2 Motherboard
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
SER? LA BIOS O EL HHDD MUY GRANDE??
NO NECESITAS ACTUALISAR EL BIOS,ESTE TABLERO MADRE PUEDE LEER EL DISCO DURO.
LO QUE NECESITAS HACER ES CREAR UNA PARTICION DE 137GB O MENOS AL PRINCIPIO DE INSTALAR WINDOWS.
LUEGO PODRAS CREAR OTRA PARTICION DESPUES DE INSTALAR WINDOWS.
CLICK DERECHO EN "MY COMPUTER ICON"/MANAGE/DISK MANAGEMENT,Y SIGUE LAS INSTRUCCIONES.BUENA SUERTE
Jun 19, 2008 | MSI KT600 400FSB (KT6DELTALSR) Motherboard
EliteGroup PM800M2 Motherboard Logo
1,307 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
