Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My whirlpool refrigerator is running water the entire kitchen and living room was flooded lastnight
  • 943 Answers
Hi thanks for the question. Its more than likely the water valve for the Ice maker.stuck open. replace the water valve
Posted on Dec 23, 2008
I woke up last night with water running from under my refrigerator flooding my kitchen & basement. What could be causing the problem? Also how do I remove the evaporator pan? So much stuff is...
check and make sure that the water fill valve does not have a crak in it usually not enough water in the defrost pan to cause any kind of flooding issue. it is either a bad water valve or a broken water line somewhere on the unit
Sep 08, 2010 | Kenmore 54383 Side by Side Refrigerator
Water Flow out of freezer compartment
take wires off inlet valve if it stops replace ice maker
Aug 31, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Water dispensor comes on by itself and floods kitchen
You need to replace the switch! You should do this before long to prevent it from flooding while you are asleep or away from the house. Please call us for parts! We will be happy to get this for you. Ella
Aug 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Water is running into the ice maker
hi thanks for the question yes there is a water valve at the back where your water valve is replace the valve thanks the appliance doc
Sep 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
