Question about Gateway 2520915 Keyboard
Keyboard `problem `strange `dash `appearing
Every `time I `hit `the `space `bar `a `little `dash `appears, `as `you `can `see `here! `Could `someone `provide `a `fix `for `me? `Thanks. By the `way `my `operating `system `is `vista
  • milnedanny Dec 23, 2008
    hi `thanks `for `the `reply `do `you `know `what `combination `I `should `be `using `to `get `rid `of `these `annoying `dashes?
    Thanks
  • seanlikescak
    seanlikescak Feb 08, 2013
    My belkin keyboard does the same on my Acer Aspire One laptop, Except instead of the dash, whenever I press the spacebar the volume goes down by one. So I can't playgames without constantly turning down the volume, or even play music and do stuff on e the internet. It really is a problem...
    Guru:
  • 829 Answers
Many programs extend the usefulness of the function keys by using key combinations. The most common combinations are Shift + a function key, Alt + a function key, and Crtl + a function key. These combinations can be very useful. For instance, in Microsoft Word, when any text is highlighted, pressing the Shift key plus the F3 key will change the case of the text from all caps, initial caps, to all lowercase. Shift + F7 will choose the Thesaurus command. These shortcuts allow you to access such functions with one keystroke rather than three or four mouse clicks.
Posted on Dec 23, 2008
  • Milind Shetti
    Milind Shetti Dec 23, 2008
    If keys have activated accidentally. If you decide you need to disable a key, just follow these steps:
    1. From the Tools menu, select Customize…
    2. In the
    Customize dialog box, click Keyboard
    3. The Customize Keyboard dialog box will open
    4. In the scroll box beneath the Categories label, select All Commands
    5. In the Commands scroll box, find the command name for the key or keystroke
    (you’ll have to do some searching to find the specific key you wish to disable, but here’s a freebie: to disable the Insert key, select overtype)
    6. Highlight the key or key sequence in the box below the Current keys label
    7. In the drop down box beside the label Save changes in: select Normal
    to apply the change to all documents created in Word. To disable the
    key only to the current document, select the document name from the list
    8. Click Remove and then Close
    9. Click Close on the Customize dialog box
Logitec K120 spacebar skips runs wild. How to remedy problem
I'd bet that if you pulled the space bar off the keyboard that you'll find a bunch of gunk around either the spring bar, keyswitch or both.
Either that or someone set a keyboard macro for "sticky key" on your space bar when you weren't looking.
For hints on pulling keycaps, check youtube. Getting them off is easy. Getting them back on is the hard part.
Mar 03, 2015 | Computers & Internet
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
Hit\ space\ bar\ backward\ slaches\ appears
hmm/that is unique/did something/spill on keyboard?
Jun 16, 2012 | Computers & Internet
My new straight Talk phone won't unlock
hit the dash that is ABOVE and to the left of the OK then hit the space bar on the bottom. Space bar is the widest key on the bottom and actually looks like a typical keyboard space bar.
Jun 01, 2012 | straighttalk.com
Function key bar appears on desktop screen
Start - All Programs - Toshiba - Utilities - Settings for Flash Cards
then just place a check mark in the box labeled "DisableToshiba
Flashcards"
Jan 06, 2010 | Computers & Internet
When I push the space bar I get a c followed by a space pushing m gives me ,m Holding the key down gives correct letter in succession.
It appears your keyboard prog is setup wrong. gointo your mouse/keyboard prog and reset language details?
Nov 13, 2009 | Acer 91.63X07.001 Keyboard
Space bar doesn't always work and a line sometimes appears when Caps are used
The batteries may be low or if that does not work just buy a new keyboard.
May 11, 2009 | Computers & Internet
The keyboard has gone crazy
Have you recently spilled something on it? I know that sounds silly, but I've done it in the past and the only way to fix that is to get a new keyboard! If not, try taking a qtip and popping a few buttons off of the keys you're having problems with and wiping away the dity/grime/whatever is on there that's clogging its "brain"
Please rate FixYa!
Dec 23, 2008 | Dell SK8110 Keyboard
Gateway 2520915 Keyboard Logo
1,852 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
