Question about Bosch HMT9626GB Microwave Oven
How to replace both door hooks on BOSCH MICROWAVE/GRILL
MODEL NUMBER HBC86Q650B/01, HOW DOES ONE GET THE INNER DOOR PLASTIC SURROUND OFF ?, WITHOUT DAMAGE TO REPLACE THE HOOKS.
  • paul_bartlet Dec 25, 2008
    CHEERS THANK YOU WILL GIVE IT A GO. Paul Bartlett
  • Bosch Master
  • 9,098 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
how to replace both door hooks on BOSCH MICROWAVE/ - aee9d9d.jpg
Posted on Dec 25, 2008
Can I replace the door locking mechanism on a GE JVM1650 microwave oven?
If you are talking about the 2 hooks that stick out of the door, in most cases yes they are replaceable. also the switches behind the holes the hooks go into are also replaceable. Door hooks can be accessed by carefully prying off the plastic inner door frame around the hooks. You have to be gentle or the frame will crack. Take your time and go slowly all the way around the door.
Feb 25, 2015 | GE SpaceMaker Microwave Ovens
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
I need to change the door catch, so how i take the door apart to replace the catch ??
if you mean the door hook inside the door this is quite easy you need a flat small bladed screwdriver to split apart the plastic inner part of door from the outer keep working around till you have released all the catches there are several, the inner skin will pull away revealing the hook and a spring the hook just slides out refit new hook with spring and reassemble. easy.
Jun 04, 2010 | Neff H5642 Convection / Microwave Oven
Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Feb 08, 2009 | LG Microwave Ovens
Replacing door hooks
Easy, just pry off the plastic inner door molding and replace the plastic latch hook and spring.
Mar 10, 2008 | Samsung SMH7178STD Microwave Oven
Whirlpool MH1150XMQ
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
I don't suggest your remove the door itself, because misalignment can allow leakage.
We have *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
It looks like the part is called the door latch.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 05, 2008 | Whirlpool MH1150XMQ Microwave Oven
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
Bosch HMT9626GB Microwave Oven Logo
1,527 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
