Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My whirlpool refrigerator is running water on the floor
We cant see where the water is coming from
  • 700 Answers
The water line runs thru the bottom hinge of the left side door and its covered up by a grille at the bottom at the front of the unit. and or the drain line is clogged up or frpozen in the freezer compartment. try these things and good luck.
Posted on Dec 23, 2008
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
WATER ON FLOOR COMING FROM FREEZER SIDE
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Whirlpool ES5FHAXS Side by Side...
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Sep 11, 2009 | Refrigerators
Leeking water from the bottom cant see any water coming from hose
do you have a block of ice inside frzr floor. if so, your drain is clogged. is your condenser fan mtr running? chk your condensate pan for leaks. is your wtr valve leaking?
Jul 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ice maker
could be a problem with the ice maker itself or the water solenoid that controls the water.
the ice maker itself controls the solenoid. if there is a stuck contact, then water would continue to run.
if the solenoid has a leaky valve, water would still come in even there is no more power.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
