I can only pick up analog stations and cannot pick up the digital broadcasts off my cable system using the Zenith c34w23 HDTV. Using the same connection I can pick up analog, digital broadcasts and ABC, NBC & CBS in HDTV with my Samsung HDTV. Both are supposed to have built in ATSC tuners but on the Samsung will pick up the digital side. Why would one be able to pick it up and not the other, unless the tuner is actually bad.
SOURCE: Zenith TV
I figured it out on my own, the TV is picking up a signal from DirecTV so we know it's digital.......
Thanks
SOURCE: Zenith SR2075DT 1995 TV
In your on screen menu have you gone to set up? Here you would select cable and not off air and then do an automatich channelprogramming. I hope this helps.
SOURCE: Zenith B32A24Z Digital Tuner?
I have an B36A24Z Zenith TV set Does this set have a digital
tuner?
SOURCE: Does my Zenith Model b25a11z TV have a digital
This unit only has a NTSC (Analoge) tuner to my knowlege not a ATSC (Digital) tuner.
