Question about Car Audio & Video
The protection LED on the amp is always on.and the green is off
I have an MOQ-vanquish 1200Watt amp...there were two 220uf,16v capacitors blown..I replaced them with 220uf,10v...and the amp started working. But the red LED, next to it written protection is on but the the amp does not work. It never actually worked since it was given to me by a friend..could it be that i used a different cap?please help..couse I wana **** up ma ride yo..
  • 21 Answers
Make sure you use the exact components inside the amp you can do much more damage to the amp with the wrong stuff inside
Posted on Dec 26, 2008
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
RCA R56WH78 Green LED Blinking
Ck 3 capacitors on deflection board cp150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are 220uf 35v cp114 cp120 resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA R56WH76 Projection Television
Television will not turn on
ON the Deflection board look at cp150 (2200uf 16v)- if it is puffed up on top it is bad replace it and 2 more cp114 & cp120- 220uf 35v. Radio Shack should have capacitors. they are green with gold writing on them.
HAPPY NEW YEAR!
Dec 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sceptre monitor
I would suggest looking at the capacitors on the power supply board. I just got one today with 3 blown caps (the tops are swollen) and a couple missing components.
The ones blown on mine are the 220uF @ 25V and 1000uF @ 16V.
Oct 12, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
My RCA HDTV wont come on when I turn on the power
ck capacitors cp150,cp111,cp114. green/gold writing on them replace all 3/ 2200uf 16v,330uf 35v,220uf 35v.
Oct 11, 2008 | RCA D52W19 52" Rear Projection Television
Tv just want come on
Look for bad capacitor cp150 will be Green with Gold writing 2200uf 16v also if this is bad replace the two other caps near it they will be 220uf 35v.
Sep 23, 2008 | RCA D52W19 52" Rear Projection Television
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
Veiwsonic 924x
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Dec 27, 2007 | ViewSonic VX924 19" LCD Monitor
Car Audio & Video Logo
230 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
