Question about Pioneer Audio Players & Recorders
Pioneer CDX-P22 won't read disk (car boot mounted unit)
Hi, I have a Pioneer CDX-P22 in the boot of the car, with the matching head unit. All was fine until suddenly it wouldn't play. I've takent he casing off, cleaned the read-head, re-seated the ribbon cables etc. but no go. When you switch the unit on, it cycles all 6 disks into the reader, the head moves a little as if trying to read. When you press play, the head unit displays the disk being "played" but does not display the track number, nothing happens. Sometimes it comes up with an error - I've seen error 11, 13, 14 but don't know what these mean, the manual is no help.
I'd like to fix it or replace it, but don't have much money....
I'm reasonably competent at fixing things, I can solder quite well and know how to use a multimeter no problem. I have an oscilloscope and know how to use it, but don't have a clue as to what I'm looking for on the unit.
Any help much appreciated,
RIck
  • 128 Answers
SOURCE: Pioneer PD-F1007
Hi, You need to check for schematics of the changer. They are sold in various places. Daniel
Posted on Feb 02, 2006
SOURCE: Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Posted on Jun 25, 2007
SOURCE: CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Posted on Jul 04, 2007
SOURCE: bad playback
What is the fix for this. I to have the same problem and it has been that way since the unit was 3 months old.
Posted on Mar 24, 2008
Nickstar19
  • 417 Answers
SOURCE: Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Posted on Jul 03, 2008
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer CDX-P670 Wiring / Power
hi according to the manual the two pin connector is for the power and the pin nearest the square control plug is ground, the other pin is +12, have tried this with mine and it works
Nov 26, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Lost cable between changer and head unit for CDX-P25
http://www.hermanelectronics.com/HermanStore/homepage.asp
www.vancebaldwin.com
www.partstore.com
Jan 12, 2009 | Pioneer CDX-FM1277 12-Disc CD Changer
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
Dec 28, 2007 | Pioneer GPS AVIC-X1 car radio
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
490 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
