Question about ASUS P5LD2-VM Motherboard
New CPU installed Message
Every time when I shut down my PC and Power on again befor the IDEs recognizer the screen show me this message: New CPU installed! pleaas enter to Bios to configure your system Press F1 for enter set up Press F2 for load default settings ... after any kind of change that I do, or just entering and save or load default settings the windows start without problem, but, when I shut down and shut of the elecric of the PC the message appear again. I thank any atentions (please Im not english speaker excuseme any kinds of gramaticals errors)
  • 1 more comment
  • Alex Gutierrez
    Alex Gutierrez Apr 14, 2007
    Thanks a Lot, I going to try doing that, and I let you know right here
  • Alex Gutierrez
    Alex Gutierrez Apr 20, 2007
    I try changing the battery like you explaint me and nothin, the self problem continue.
  • Alex Gutierrez
    Alex Gutierrez Jun 07, 2007
    Can be it somehow a jumper configuration problem?
I had the same problem and I found the jumper to reset CMOS was missing from the motherboard. If you have manual for the motherboard, it shows where the terminal is and it should have jumper on pins 1 & 2, it is the default setting. This is the terminal to reset CMOS. Hope this will help.
Posted on Nov 03, 2007
    President:
  • 2,961 Answers
It will probably be your cmos battery that is flat and losing the saved settings, this can be located on the motherboard, it is a flat disc shape (CR2032)
Posted on Apr 10, 2007
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
System shuts down at times. May take several times to try and reboot. When I try to reinstall windows with a CD Recovery Disk, I get an error which says Bios ACPI not comliant and will not go any further....
Enter you're bios and disable ACPI. Wait until you have at least SP2 installed before enabling ACPI. While in the bios open, Hardware Monitor & MISC Setup. Watch the CPU temp. See page 53 in you're manual.
You're system shutting down may be caused by the CPU over heating. This is a safety feature for all MBs. Suggest that you remove the CPU heat-sink assembly from the CPU. Check the thermal past / tap. If it is dried or cracked replace. Remove the old using house hold alcohol on a clean rag. (Not dripping wet). At this point there is no need to remove the CPU. Clean the CPU's fan and blow out any dust build-up within the assembly. The heat build up will cause you're system from booting untill the CPU cools. This is why it seems to take awhile for you're system to boot.
Link to Gigabyte GA-7VKML manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_7vkml_e.pdf
Gigabytes main site for GA-74KML;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1306
Cheers'
Mike
Feb 06, 2010 | Gigabyte GA-7VKML Motherboard
I accidentally updated my bios and can't get windows to boot. All I get is a solid dash in the upper left corner and Can't do anything but manually power down.. How can I get the default bios back
sounds like you may have installed the wrong bios. Did you keep a backup copy of the old 1. You should have been prompted to save a copy.
Second thing is to report exactly what was said in an error message..."something/something" really does not cut it.
Lastly it maybe that your mobo just fried itself.One should not just go to doing a bios flash unless absolutely neccesary.
You might try to restart and enter the bios again and click on the install default tab and see if it will restore the default settings. You may have to reset the date/time settings. then save and exit. If the cpu fan does not remain running shut down immediately and try placing a house fan to blowing directly into the pc and try to reboot again. If the cpu fan shuts down again then you probably blew the mobo
Sep 03, 2009 | Computers & Internet
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Turns on, then shuts down before anything shows on monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Computer turns off and restarts again during the operation repeately.
Hi 2gerr, when you tested the board, was the board outside of the you're case?
Here is one suggestion you can try. Start the PC & press the F5 key every two seconds untill Windows Advanced Options Menu
is displayed on you're screen. You can not use you're mouse here. Use the up & down arrow keys & slide to, Disable automatic restart on system failure. Than press enter. What this should do for you is stop windows from restarting & give you time to catch what is causing windows to restart. If you receive a blue screen with an error message write it down. Press the pause key on the keyboard so you'll have time to write down the error message. It would not hurt to enter you're bios and turn off hault on all errors listed in the main menu of the bios.
Another could be the back side of the board could be touching the case. You can add a piece of a paper bag under the board.
Stopping a possible short. Lastly, enter you're bios & go the hardware monitor. Open hardware monitor & leave it there. Shut off you're monitor & walk away for about 10 minutes or so coming back from time to time & check the temp of you're CPU & mother board temp. Staying in the bios, let me know if the PC restarts.
Mike
Apr 25, 2008 | EliteGroup P4M800-M7 Motherboard
Pc starts up and shuts down repeatedly and no video
First be sure that the ram (ecc)you have purchased is compatible with your motherboard and that it will take a total of 4 gig,make sure you earth yourself out on the case before going inside the pc (static electricity can damage electronic components)check that you have not accidentally loosened any data or power cables, check cpu & fan is seated correctly and working : then
  • put back the old ram and try booting up,(if still no good),
  • put things back to the way it was before the changes,
  • make sure everything is working as before (refer to the above)
  • trying the new ram, if ok
  • change cpu
  • this will identify if it is the ram the cpu, or some other problem
it is a good idea when upgrading the pc to do one thing at a time so that it is easier to identify any problems that crop up.
let me know how you get on
good luck
Terry
Mar 23, 2008 | Computers & Internet
ASUS P5LD2-VM Motherboard Logo
306 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
