Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Jenn Air wall oven-Broiler element comes on and will not turn off....
I have a 27" Jenn-Air wall oven (convect bake model). When we try to bake something normally by just pressing bake and selecting the temp, the top broiler element comes on and will not turn off. Eventually we'll get the F2 code displayed. The lower element never does come on. The only way to get the oven to turn off is to turn the breaker off. We let the oven sit with the breaker off for several hours then turn the breaker on and try again, but the problem persists. Can you tell me what is wrong and ballpark the cost to fix it? Thanks.
  • 1 more comment
  • Mike Sullivan
    Mike Sullivan Sep 16, 2012
    I had same problem, and yes, it is the power relay board, but all you need to do is replace the relay, not the whole board and you will save about $100.00, easy replacement with solder iron and parts were only a few dollars, and I would replace both while you have access to board.
  • Anonymous Mar 12, 2014
    my ovens will not shut off unless I turn breaker off when I turn breaker back on they heat up again
  • Anonymous Mar 24, 2014
    element damaged
    President:
  • 878 Answers
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Posted on Apr 10, 2007
  • Bill Stender
    Bill Stender Nov 03, 2013
    I just had the same problem on my Jenn Aire SVE47600. I tried your suggestion to swap the wires going to broil and bake points. When I flipped the breaker on, neither element came on. So I swapped them back to their correct positions and now the oven is functioning normally. I've only tested it 3 times so far so I'm not sure it will stay fixed...any idea what could cause it to function correctly with what I've done?
    Scholar:
  • 120 Answers
I have same problem and have identified it as the relay, so does anyone know where to get just the relay, not the whole board?
Posted on May 24, 2010
Bake Element
I would start by checking the temp sensor of the bake temp settings. Pull it and its most likely bad your thermostat control, also did you ohm out the element before installing it i have bought many new bad ones as well. anything else just ask.
Apr 05, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
HI. this is a failed oven temp sensor or relay board.
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Ohm test the oven temperature sensor, if OK, change power relay board.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
1,313 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
