FixYa.com
Tags:
Proton MM2701VT 27
What is 16:9 Aspect Ratio and how do i know if i...
By Bouncy - usenet poster
What is 16:9 Aspect Ratio and how do i know if i have it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Green1
Green1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
or 16:9 aspect ratio is more of a wide rectangle and it's similar to the shape of a movie screen. Someday all of the TVs available will be 16:9. It makes sense really. Movies are shot with a particular shape in mind. Our culture tends to not only go to the movies, but to also watch movies at home on TV or DVD or VHS.
When you watch a movie at home on a 4:3 TV set you have two formatting options. You can either add the black bars to the top and bottom of the screen or you can cut the edges of the picture off and not show them at all. No matter what option you choose there are drawbacks. Either you are not using the whole TV for the movie, or you are missing part of the movie. With a widescreen TV this isn't a problem. You get to see the whole movie and use as much of the screen as possible.
Widescreens aren't just for watching DVDs either. Right now, most TV shows are in the old 4:3 format. But HDTV shows are filmed and broadcast in the 16:9 aspect ratio just like movies. Some camcorders even allow you to film in 16:9. The widesreen aspect ratio is definitely the standard of the future.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 01, 2006
Not Rated (0)
Liver
Rating: 0%, 0 votes
LX3262 bad solder joint (repaired). Replaced shorted Horiz. Output QX3208 and also blown fuse FX3403. Everything OK now except that picture is extremely wide and the menu adjustment does not correct. Horiz. width adjustment R3249 does not have any effect on the picture at all. Can't identify the damper diode. Any help will be appreciated. Thanks, Liver
This Problem Also Relates To: GE 24GP653 24" TV GE 25GT240 25" TV Jensen TS2050J 20" TV Panasonic CT-27SL15 27" TV Sony FD Trinitron WEGA KV-36FS320 36" TV Sony KP-61HS30 TV Sony KV-27FS16 27" TV
Can you Help with these Standard Televisions problems?
Proton MM2701VT 27" TV
JVC TV won't turn off
On occasion I will be unable to... Answer This...
PHILIPS GRAX1 CHASSIS
i have a picture and all... Answer This...
50" Samsung
My tv turn off by it self. The... Answer This...
50 ' Samsung DLP pausing
model #HLN5065WX/XAA My tv... Answer This...
Magnavox 32in
This TV is Model MS3252S431 and... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
