Question about E-Machines eMachines T3830 PC Desktop
Building a new PC, cannot get LCD to work
I am building a new PC. Details as follows.
MOBO - Gigabyte EP45-DS3
HDD - 1 TB SATA 7200
RAM - Kingmax 1024MB PC2-6400 800 MHz DDR2 - CL5
Patriot 2048MB PC2-6400 800 MHz DDR2 - CL5
CPU - Intel DC E5200/2.5GHz/2MB cache/800FSB/LGA775
case - 600 watt MDI ATX
Monitor - LCD View Sonic 20'
I have physically built the computer, but I cannot get the LCD to receive signal. I tried the monitor on a known working PC and got a signal, so the monitor is not the problem. I disconnected all components and refitted (without any luck). I read that sometimes the MOBO can short out on the case, so I tried running the system out of the case (without any luck). I have stripped the PC back to bare minimum, HDD, GPU and power (and still no luck).
I cannot get into the bios to troubleshoot settings.
There is no on-board graphics to switch to.
All fans are running, the HDD is spinning up okay.
  • jezza70 Dec 24, 2008
    "Their is a note on your particular mother board to check with the compatable CPU chart. "
    My CPU is on the list, so we can rule that out. I will try attaching the tower to another monitor, and failing that will try and get into the BIOS. Don't like my chances though as I am not getting anything at the moment.
    Here goes.......
    I have tried, again, to access the BIOS (no luck).
    I have changed the RAM ( no luck)
    I tried a different monitor (no luck)
    I fitted the graphics card into the other slot (no luck)
    It sounds like I have a bad graphics card or MOBO. I do not have access to a similar graphics card to rule that out, same with the MOBO.…....
    Any suggestions...please!!!
  • 78 Answers
You MUST get into bios to set "initalise display first"selection.
try alternatly pressing delete,or f1 keys toget into bios.
one of the two will get you "in"
then follow instructions at bottom of screen to navigate.
if you have a pci or agp grafix card,select it accordingly in "ini display"settings.
and if you still dont get a screen,set jumper on mo-board to clear c-mos.
and if you STILL dont get display(happened to me with a dell monitor(lcd),the monitor wont work with the computer.
--try another monitor!
most anything will display in 256 colors via the op-sys till you install the grafix card drivers and utility.
good luck!
Posted on Dec 23, 2008
    President:
  • 2,692 Answers
What GPU video card are you using? It is seated well?. If I have the correct MB specks. have you tried the PCIe VIdeo card in the other slot?   Another thought. Their is a note on your particular  mother board to check with the compatable CPU chart.
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=2843
    Genius:
  • 2,785 Answers
Try with other ram if everything fails then motherboard is the culprit
Intel DH55TC Motherboard does not recognize the internal dvd burner in BIOS
Update your MOBOs BIOS. also check the connection points on the mobo to see the SATA connection is impeded or messed up in any way.
Aug 22, 2012 | Intel DH55TC Motherboard
Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.
Now boot into Windows and click control panel.
Double click Administrative tools and double click Computer Management.
Left on screen: Select Disk Management under the heading, storage.
Here is where the hard drive should be detected. If not present click action, followed by refresh.
Now select your new drive and format it using NTFS.
Take care!
damnor01
Jun 07, 2012 | Gigabyte GA-8I915ME-G Motherboard
AcerAspire M1641 total capacity of all HDDs limited by MCP73VE mb
It is up to 1TB per drive. RAM is totally different and has nothing to do with HDD capacity.
Jul 23, 2010 | Acer Aspire M1641-U1521A PC Desktop
Gigabyte g31m-es2c motherboard can't detect my sata hdd
dude make sure if the jumper pin is set properly
as i think your MObo is sata 1 support and all new generation Hdd are sata2 support so u have to set the jumper pin. the setting are different fro different Hdd so check the producers website.
Mar 16, 2010 | Intel Motherboard
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a packard bell IMEDIA MC 2559 PC The mobo's P/N : PB34316801 I got a new case for my son to build a PC for the first time and we got this mobo from ebay...
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
Feb 14, 2010 | Gigabyte GA-6WMM7 Motherboard
Am I put SATA HDD of 80 GB and 1 GB DDR1 RAM in my LG My PC Captain of India Pentium 4 Computer?
i was not able to undestand the Q properly but i think u wanted to say if u can place sata 80GB hdd & 1 GB ram in your P4 pc.
so here is how it works until u give your motherboard name or your pc manufacturers model number we guys can say nothing !
Feb 03, 2010 | Gigabyte GA-EP45-UD3P - Motherboard - ATX...
Install a second sata hdd to a gigabyte ga-p35-ds3 rev 2.0 motherboard not in a raid array configuration, so I can do a clean install of windows 7 to my new drive and leave xp on my old drive.
ther is no need for a raid array. connect hdd assign priority to the new hdd. install 7 on new hdd,
or
just connect hdd , boot to xp , put windows 7 dvd , instal it on new hdd while u r in xp
if ur new hdd is not detecting just clear c-mos settings
Jai
Oct 23, 2009 | Gigabyte Computers & Internet
I have just purchased all new parts for my computer ( im building from scratch) i haev got everything connected i got to swithc it on and all that happens is a bunch of small L.E.D's flicker once...
Did you double check ALL of the connections for power on the board? Check and see if your memory is one of the approved modules from the website for gigabyte. Sometimes an unapproved ram will cause a board not to boot. Also check and see if you have seated the cpu correctly.
Jul 11, 2009 | Gigabyte GA-EP45-UD3L Motherboard
Motherboard compatibility
If you want to replace the mobo always compare the cpu-slot and the memory slots.
Tok a fast look on both of the mobos and both supports same cpu, both supports same memosticks though the the one you have supports ddr2 667mgz and the new one you found supports ddr2 1333+mhz. So you can use it but you may have to buy faster memosticks if you want to use the full power of it.
Here is the support site for the new one:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2843
On that site you will also find all the drivers you may need if you buy it
And here is the support site for the mobo you have:
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ClassValue=Motherboard&ProductID=1960&ProductName=GA-8I945P-G-RH
Now you can compare yourself if you want.
BTW, that GA-EP45-DS3 is a very good mobo
Good luck to you
Please take a moment and rate my help for you
Nic
Feb 18, 2009 | Intel Motherboard
Ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Mar 30, 2008 | Computers & Internet
E-Machines eMachines T3830 PC Desktop Logo
175 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
