Question about ZT Group CISNET A7050 PC Desktop
Attention no signal on monitor
Monitor has gone black
    Genius:
  • 2,785 Answers
When your pc is on plz remove the monitor cable from the cpu and check if there message displayed in the monitor, if you any message then your monitor is ok, if you dont get then your monitor might be defective.
if your monitor gets a message then try the following
try by resiting the ram, if it doenst work than you have to send the mother board for sevicing
Posted on Dec 23, 2008
Attention no signal
Check this out with another PC to confirm the case before you can suspect the monitor. If so it can be due to failure of the signal processor within the monitor and so a hardware service is required for replacement of the IC.
Jul 04, 2012 | Envision G175 Monitor
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
My monitor screen is black. The green light is on but black screen
The green light usually indicates that the monitor is getting a signal.
The lack of a picture is an indication that the monitor itself is having a problem. I would test the signal with another monitor if you can get one.
I suspect that the monitor backlight has gone bad (if so, you can see the screen very faintly if you shine a light on it).
Or, the screen circuitry has gone bad.
Jun 30, 2011 | Computers & Internet
Have signal, but no light, just one second screen can see and shut off.
Please clarify by shut off you mean power light turn off or just screen gone blank but power light remain on!
Mostly inverter(power supply) needs attention in such cases.
Feb 07, 2011 | Dell E198FP 19" LCD Monitor
Display will not come up, screen remains black, blue light on front of monitor flashes on and off
Check that the monitor is still receiving a signal it could have gone into standby mode.
If not you either have a faulty inverter or the back light has gone, to test this when your computer is on is to check you can still see a faint image on the screen that means the backlight has gone, if not its the inverter.
Jan 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
It is turned on but screen stays black once tower is powered up.
we need to make sure whether its a Tower problem or monitor Problem>
Do this simple test> Disconnect the Cable that connects the Tower to the Monitor(while the tower and the monitor are on)> then see if you have any error msg on the monitor screen> if you have someting that says "Chk video cable" or " no signal"
Ur monitor is fine and the tower is faulty> IF not thn ur monitor has gone bad>
Oct 20, 2009 | HP 75 17 in.CRT Conventional Monitor
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
ZT Group CISNET A7050 PC Desktop Logo
300 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Jose Pino
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
