Question about Xerox DocuColor 3535 Copier
Gives pink shadow on printing card paper 12 * 18
I had problem since i baught the RC machine it shoots pink shadow on both the side of paper we have cleaned Dp.,Laser,RVT. but the problem still comes in starting 3 to 4 sheets and then it's disappier. is there any solution
    President:
  • 2,072 Answers
One of 2 things, Replace the transfer cleaning blade. You may be able to clean it and get rid og the problem. The second thing to try is to replace the magenta drum, but thats less likely since you say it goes away in 3-4 pages.I suspect the transfer blade.
Posted on Dec 23, 2008
  • Rick Kasper Dec 23, 2008
    Ohhhh, I just thought, It could also be coming from the fuser pressure belt. Does it look a but oily? If so, select 10 pages, when the machine is just feeding one out, shut the machine off to jam it. Then see if the image problem is before the fuser. It just popped into my mind that if the pressure belt was replaced and there was excess lube put on the belt edge, you may be picking up some of that.
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
Head cleaning
Please don't try to clean the "head" A laser printer is a very delicate apparatus and can be dammaged very easy. The manual gives several reasons, why shadow's can apear. One is the paper could be to moist. You could see the manual (still online) to check what "shadow" is closest you what your machine produces.
Maintanance starts at page 72 and is followed by trouble shooting, where you can see print errors.
Nov 05, 2013 | Samsung CLP320 AllInOne Laser Printer
When auto print is pressed the machine blanks out and nothing prints
Try this link to slide share for a colour rendition of the user manual
http://www.slideshare.net/DiscountCardiology/schiller-at-2-ekg-manual
Aug 30, 2012 | Schiller Cardiovit At 2 Light Ecg Machine
Sharp MX 2300n - When I print or copy color, the whole page has a pink hue to it. Not there when printing or copying black/white. I have cleaned the laser holes and pulled the corona knobs several times,...
PRESS #*c* in your control console respectively then you will get a service mode,Check to confirm that there is A3 paper in the paper feed tray. If paper is insufficient, supply it, will ask for main code press 67 then press Start and machine will ask for a sub code press 24, then machine will give you another display press execute on that one, you will get a pattern print out. After completion of self-printing, the display is shifted to the output patch scan start standby screen. Make sure toplace the printed test pattern on the glass pointing the light side of the pattern towards the left hand side that is to place the light side coinsiding with the arrow marking on the glass table, place some white A3 sheet above this to correct the white value, press service and then press execute then machine will give you another print out then on that you press ok on that one and wait for the below display message.
PRINTER ENGINE HALFTONE AUTO ADJUSTMENT MODE
COMPLETED THIS PROCEDURE.
PLEASE QUIT THIS MODE.
After this press CA button on your console and check the copy, repeat the same procedure for 4 or 5 times if the copy quality needs to be get improved. Rate this and vote for this
May 13, 2011 | Sharp MX-2300N Color Copier
Wont print
These machines can be a little finiky when replacing the paper in them try to take some of the paper off of the pile then take the paper your going to load and stand it on end and tap it like you would a deck of cards then turn it side ways and do the same. Once you do this reinsert paper and gently move paper back and forth into the feeding tray then try again, it has to make it to the paper feeder sensor to work then try again if it does not work let me know and I will try to help you some more on trouble shooting. You can also go to http//www.hp.com insert your model number and search paper feed problems and it will give you step by step instructions to sovle your problems. Thanks for using fix-ya.
Jul 22, 2010 | HP Deskjet D4360 InkJet Printer
When printing, in particular photo's there is a pink strip appearing on the left side of each image.
turn on/off, unplug, plug in, should reset configs.
check the rollers to make sure no paper or particles are stuck take all the paper out, put half as much back in.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome site for trouble shooting problems
hope this helps and good luck
Apr 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
RE: CANON LB3340 LASERSHOT - WHEN PRINTING ON A5 PAPER PRINT IS SHADOW PRINTING AND NOT STICKING TO PAPER.
there is a "fuser" (hot roller) that is used to melt the toner onto the paper .. if its bad then the toner will not stick to the paper .. the fuser is after the drum and before the exit shoot ..
Feb 28, 2010 | Canon LASER SHOT LBP 3360 Printer
Schiller AT-2 Plus, placed new paper in machine and machine keeps stating "out of paper" and will not print unless I hold down the manual print.
Your machine has the wrong paper in it or the paper sensor is not working properly.  There should be a black mark on the top left hand corner of each page.  The correct ekg paper and ekg repair is available from Medical Device Depot.
Feb 15, 2010 | Schiller Welch Allyn Cardiovit At 2...
"shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Jan 02, 2008 | Brother HL-2040 Laser Printer
Canon i990 prints are too "pink"
I had the same problem and it turned out to be a combination of the actual paper and media type. Brother brand paper just printed way too pink and some Ilford papers did also. I had an image that was desaturated and even when printing as a greyscale came out magenta.
Was three nights of hard work to get sorted. try printing on plain paper with media type set to plain paper. good luck with it though, I know how frustrating it can be!
-A
Nov 09, 2007 | Canon I990 InkJet Photo Printer
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
