Question about Acer Aspire E500 PC Desktop
How to expand max memory capacity on acer e500
I have an acer aspire e500 desktop pc (ASE500-U-P6200-R) 2005
the tech spec says: max ram 2 Gb on 2 slots (max 1Gb on each)
is there any way i could expand the max capacity of memory on each slot? for example, 2Gb on 1st slot + 2Gb on 2nd slot so i have 4Gb...
thankyou...
  • 39 Answers
You see, forcing the slot to receive more than its max (factory-default) capacity could cause unknown side effect that could leads to damage to either memory, mainboard or both.
But if you're lucky, it just detect 2GB but got somewhat increased performance.
But you have to be a risk-taker because I
really, really am not recommend this.
Posted on Dec 23, 2008
    President:
  • 2,692 Answers
The Tech is correct. Two Gb Ram is the max ;which is based upon the BIOS and engineering of *********** board limiation.
When i put 2Gb of ram..My PC keeps shuting down...is there any fix for that!?!?!?! Please help me
Every pc/laptop will only accept a certain amount of memory. Your probably overloading it. Check in your system info to see how much it can take. Also, make absolutely sure that you have the right memory stick for you pc!
Mar 21, 2014 | Acer Aspire E500 PC Desktop
I have Acer Aspire E500 (ASE500-UP801M) running Win XP Media Center edition, 1G RAM. It is too slow. Q1. Could I add another RAM stick to it and how much maximum could I add? Q2. How do I know the Bus
Test your computer using a brand new hard drive. 1GB memory is enough. I am sure this is a software problem (messy registry or problematic apps or malware) or space problem (the hard drive is almost full).
Feb 27, 2014 | Acer Aspire E500 PC Desktop
Information about how to expand RAM in Acer Aspire 1403LC
Most RAM will work with each other, but the safest way to be sure is by checking the speed. On the stick that is in there now you should see a label that says something like PC2100 DDR. I looked up the specs of your computer and this RAM should work for it.
512MB DMS Certified Memory 200 Pin DDR PC2100 266MHz 64x64 CL 2 5...
Jan 23, 2014 | Acer Aspire 1403LC Notebook
Can I use DDR2 in an Acer Aspire T135?
The e RAM specifications for your Acer are -
Memory - DDR 266/333/400 expandable up to 2GB
Jun 11, 2011 | Acer Computers & Internet
I HAVE 6 GIGABITE OF RAM,HOW CAN I MAKE USE OF ALL THAT IS THERE?
You can't. According to the specs listed for your computer at Acer, it's max is 4GB.
Memory 256MB DDR2 533/667/800 SDRAM expandable to 4GB
Ray
Mar 10, 2011 | Acer Aspire™ T180 PC Desktop
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Instal new rams to up grade from 1 gb to 2 gb
Either the RAM is not compatible or not inserted correctly. Try removing and reseating both modules, if no change try with only one stick then switch and try just the other to see if the problem is just with one. You could also try resetting the BIOS to factory defaults.
Jan 05, 2009 | Acer Aspire E500 PC Desktop
Acer Aspire E500 PC Desktop Logo
471 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
