Question about Epson Stylus Photo EX InkJet Printer
Epson photo ex head clogging
I can't get the heads to unclog using teh clean fucntion. Is there a user fixable way to clean them mechanically if teh software can't do it?
  • Epson Master
  • 705 Answers
Hey Bob Get in touch with the http://www.TheServiceManualShop.com and ask them abouth the manual cleaning methods for your printer. They have a document that is very discriptive about cleaning clogged nozzles.
Posted on Apr 12, 2007
Printer heads clogged on an epson stylus photo R1800. anyone know a repair facility in the Jackson, MS area?
put the printer head in ultrasonic tub with some alcohol, it will unclog your head for sure, if you dont have one u can just plunge it in some alcohol until clogged toner leaks out, u can notice it when alcohol changes the color
Oct 25, 2011 | Epson Stylus 2200 InkJet Photo Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Iam printing blank pages, I have no errors and
The print head is clogged.Try unclogging with cleaning tests in maintenance mode.If not help better think about new printer, because the cost of new print head is profitable.
Nov 16, 2009 | Epson Stylus Photo R200 InkJet Printer
My canon pixma ip1980, does not work the power ON, the cartridges were fine( they are new). please help me.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the print head?
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
After cleaning the nozzles, the quality of print is still very poor. What should we do?
HTML clipboard HTML clipboardHi
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Canon Office Equipment & Supplies
Canon pixma 3000 won't print red
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the magenta *red.
But provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Good Luck!
Tinteiros (Ebay)
Oct 28, 2009 | Epson Stylus C86 InkJet Printer
Epson r220 printhead cleaning
Helps to turn the printer off when not in use as the heat tends to dry out the ink. Sometimes the heads just quit and have to be replaced. If you are sure it's just blocked remove it and flush with soft water, then buy some windex window cleaner, make a solution of 100 mls cleaner 200 mls soft water and soak overnight , flush with soft water and shake dry, hope it works.
Mar 03, 2018 | Epson Stylus Photo R220 InkJet Printer
The print heads are clogged with dry ink.
Yup, thats the problem....
To keep them clean you need to almost use the printer weekly....or at least once per month min....
Try running the head cleaning utility....
You can run it as long as you have ink in your cartridges, maybe 5 times in a row....Wait about 10 minutes and try again....
With luck it will unclog itself....
Note: Your cartridge can also dry out (Yes the liquid evaporates), and leaves the pigment in the cartridge, which can further clog your machine....
As a last resort there are a few vendors on the internet where you can purchase head cleaning solution for epson cartridges....
Note; This problem is more common with printers that use pigment based ink as it tends to settle in the cartridge. Dye based ink has a shorter "Brilliance lifespan" but tends not to clog...
Feb 09, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo EX InkJet Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
