Beko 42WP300PS switching on
I recently tried to turn off the tv (standby button on remote), but it took longer than usual (which happens more often) so I switched it off with the button under the tv to fully turn it off (which turned out to be a bad idea). I turned it back on. The light was still blue (on) instead of red (standby) and it immediately stopped.
I could only turn it on by holding the button on the tv for turning it on. So when I hold the button I could set it on stand by, but that doesn't matter because it always automatically stops when i release the button of the tv...
Thank you for reading and hopefully somebody has a solution..
SOURCE: Need Help big screen turns on thens goes off
The blinking light tells you what is wrong with the circuit. If it blinks 3 times it is the convergence amplifiler. I had this problem and tried to fix it myself and I don't think that I have it connected good enough. I know this is the problem with mine. I will let you know if this fixes that. Let me see what 5 blinking lites mean. I will tell you what each blink means from the repair manual, 1 blink is +140 circuit, 2 blinks is Low DC, 3 blinks is convergence, 4 blinks is HHS, 5 blinks is IC4011, 6 blinks is IC4018. I hope this helps. You can get a repair manual at servicemanuals.com it really helped me. I will let you know how my repair goes. I hope this helps. Rick
Posted on Dec 12, 2007
SOURCE: Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Posted on May 01, 2009
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
Posted on May 06, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
tvtek
  • 1284 Answers
SOURCE: Samsung HLS5679WX/XAA DLP TV set. Problem when I
Check for a defective lamp. Open the access door where the lamp is, remove it and see if visually it looks defective.
Posted on Sep 08, 2010
Beko 20lb450
If your TV is going to standby, it is most likely not getting a signal. Try using the input button on the remote to check other inputs. Also make sure the source (DVD, Cable, etc) is on and plugged in properly.
Apr 10, 2014 | Televison & Video
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
Standard tv jvc av-28wfr1eks switches on then off
What happens when you try to turn the TV on from the button on the TV?
Feb 07, 2008 | Televison & Video
Medion lcd hd 31.5 inch tv won't turn on
I bought one also from ALDI for my son's Xbox 360, it is only 3 weeks in use and I have the same problem. The red led is on, indicating that it is in standby mode and recieving power but I can't turn it on either by pressing the power on button on the TV it's self or the on button on the remote. This started happening a few days ago and it's totally random. I found that if you unplug the TV from the power point or alternatively switch off the power point for a minute, than power it on again it will "WORK AGAIN" for a while. Like I said it is random, eventually it will return to the not being able to be switched on state at which time you will have to repeat the process. So thus, this is not really a solution. I am about to return the TV for a refund, and it's a shame because otherwise it's not too bad. and looks OK too.
Jan 21, 2013 | LG 37LC7D 37 in. LCD HDTV
No standby light
Depending on the brand and MODEL number here is what I think happened.
All TV sets have a Standby power supply. It runs all the time even if set is off but plugged in.
It supplies among other things the power (usually less then 12 volts DC to run the remote circuitry---It usually is not fuse protected so if a strike hit nearby it may have come in via the power cord.
Trouble is almost certain to be in the standby supply.
Mar 17, 2012 | Televison & Video
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
I have lost the remote control now the tv will not turn on
The remote should not have any effect whether the T.V. turns on or off.
Have you tried to press the power button so that the standby light is on? On most Tv's the light should be red. Once the standby light is on press the button on the TV to change the channel, either the + or - button. This should switch the tv on.
May 03, 2011 | Televison & Video
How to tune in beko tv with RC647340 remote
Hi ,
option one :
  1. Hold the "MENU" key down to access the TV Tuning menu.
  2. Once activated, the VOLUME +/-,
  3. PROGRAM +/- and
  4. STANDBY buttons are used.
option two
  1. on your remote control go to the menu button,
  2. go to settings,
  3. run auto tune.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Apr 03, 2011 | Beko 142746 TV
Hello i need codes for asda's universal remote model URC20-D1F so i can sync it with my BEKO tv please can you help?
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Dec 27, 2010 | Beko 142746 TV
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
