Question about Sport & Outdoor - Others
My poulan snow blower keeps breaking sheer pins in the wheels,
Sheer pins keep breaking on both sides not all at same time but one breaks then the other later, the machine feels like each side is fighting the other one side pulls then the other and again, ive treid moveing the skids down on both sides but no difference, its a poulan snow blower 10hp two stage, with big traction tires, model #961940003. thanks
  • Alphatango1 Mar 09, 2009
    I've gone through 5 drive shears this year. What's up. Never went through more than 1 a year b4. Am I missing something like a frozen shaft or something?
  • 78 Answers
1)try replacing them with a heavy duty "roll-pin"
these are available from auto parts stores.
two types are available.
first is the "single-roll",second is the"multi-rolled"with many layers to it.
try both they're cheap.
2)try not hitting things with the blades
3)dont force the machine in heavy wet ,or frozen icy packed snow.
Posted on Dec 23, 2008
My mtd yard machine snow blower gear turns freely, doesn't turn with the wheels. found problem when blower would not move
if u ck the pins in the center of your wheel hubs , you may see one or both missing , these pins are to allow one to free wheel the blower to "push " it easier , they do rust and break off over time
Dec 13, 2016 | Garden
Need to decrease Wheel Speed. Blower works well except for this. Keeps plugging up, because it moves to fast.
part of the drive plate. Lift the machine up on it's auger and take the bottom cover off. with the speed lever at its slowest see if the little friction wheel moving linkage can be adjusted so the friction wheel gets as close to the middle of the drive plate as possible. Sometimes it's just an adjustment on the shifter arm.
http://www.ereplacementparts.com/poulan-pp11530es-96192001901-snow-thrower-parts-c-16962_168114_294540.html?page=4
loosen and adjust item 20 and 25
Dec 14, 2015 | Garden
I have a 22" craftsman snow blower walk behind. i managed to pick up a piece of wood while snow blowing. it sheered two bolts which i replaced. there is still a clunking in every revolution that i can
look at auger inside behind the pick up screw i bet it got bent from wood piece and is hitting side of housing
plus my son showed me a neet trick to use a timing light attached to plug wire and 12volt battery you turn the advance adj on light point light at suspected bearing or scuff point and you can see it plain as day (engine running of course ) use extreeme caution when doing this !!!!
Nov 30, 2014 | Craftsman Snow Blower 22 In. Dual-Stage...
Why does the shearpin in the driveshaft break on a simplicity p1728e snowblower all the time
You're either working it too hard (heavy hard-packed snow) or picking up rocks. Better that you break a shear pin than that you damage a shaft or the engine! Shear pins are CHEAP compared to engines.
Feb 27, 2014 | Simplicity I924E 2-Stage Snowblower...
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Toro 828 oxe blower shear pin
knock the broken one out with a punch and hammer put a new sheer pin you can make on with a bolt just grind down the middle of the bolt so it is thinner than the rest , I do this all the time
Dec 12, 2013 | Toro Power Max 828 OXE Snow Blower - 28...
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Dec 03, 2013 | Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
Sport & Outdoor - Others Logo
682 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
