SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
SOURCE: what kind of dado blade can I use on my craftsman
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
SOURCE: Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Testimonial: "Thank you very much, I'll try Sears first and see if they can help. Since it's an older saw, they haven't been much help up to now."
